Fairbanks Morse 25 Hp YH
this thread has 24 replies and has been viewed 3972 times
Old 06-11-2017, 04:52:44 PM
cherob cherob is offline
Default Fairbanks Morse 25 Hp YH
I have recovered a Fairbanks Morse 25 HP model Yh that has been sitting in the bush of Northwestern Ontario since 1933. It is a 1923 model with the center head injector. i have it home now and am disassembling it, the cylinder is stuck and it is missing the Madison Kipp oiler but otherwise it looks to be complete. It is apparent that a bush repair was done on this motor without proper tools. The cylinder head nuts have been rounded off with a pipe wrench and a broken ten inch piston ring was found on the forest floor close by along with a copper/asbestos head gasket. My question is, what is the proper head gasket for this engine. When I removed the head it has two paper type gaskets between the head and cylinder and another between the head and the injector housing. Has anyone had experiance with the gaskets on these engines and if so who did they get the replacements from?
Old 06-12-2017, 07:52:02 PM
Contaucreek's Avatar
Contaucreek Contaucreek is offline
Default Re: Fairbanks Morse 25 Hp YH
http://www.gasketstogo.com/
Maybe worth a try.
Old 09-07-2017, 04:08:06 PM
I did get John at Gaskets to Go to make some head gaskets for me! I now have the Piston out of the cylinder and the rings off the piston without breaking. The black tarry substance that is on every part of this motor is unbelievable but I believe that is what has kept the internal parts of the engine in good shape. I will spend the winter cleaning parts and reassembling. Still looking for a rebuildable three feed Madison Kipp oiler! Hope to hear this machine run again within the next year if I am able to find one....
The Following 3 Users Say Thank You to cherob For This Post:
Old 09-07-2017, 08:06:09 PM
56Townsman 56Townsman is offline
Would enjoy seeing some photos of the beast, if possible.
Old 09-08-2017, 11:59:55 AM
Chuck Moss's Avatar
Chuck Moss Chuck Moss is offline
The oiler originally provided for the YH's was a Madison Kipp Model 50, with two pressure feed lines (cylinder & connecting rod) and a gravity drip line to the governor eccentric. A drop in substitute is the Manzel Model 25D, which can be configured with several configurations. I say "drop in" somewhat tongue in cheek, as I did need to make a simple adapter plate to provide mounting holes in the right places.
On my YH I got a four pump Manzel 25D off of Ebay, removed one of the pumps and installed a cover plate to fill the space from the removed pump. I bought the cover plate from Lubriquip. Looks like the product line has been bought out and/or name changed to Graco which still manufactures Manzel 25D oilers. http://www.graco.com/us/en/products/...ubricator.html
The Following 2 Users Say Thank You to Chuck Moss For This Post:
Old 09-08-2017, 12:14:19 PM
Maybe if I find myself in the northern part of our great Province I might shout out to you for a look see at that great engine!
Old 09-08-2017, 05:27:44 PM
I have never posted pictures before so I hope this works. These are some of the rescue operation once we got it to the water's edge. From here it was floated some thirty plus miles through a series of rivers and lakes to a landing from there it was hauled by road to my shop...
ID:	290707   Click image for larger version
ID:	290706   Click image for larger version
Help with Fairbanks Morse Z 1.5hp cpl1081 Antique Gas Engine Discussion 16 07-06-2016 09:20:21 AM
Fairbanks Morse Z thiggy Antique Gas Engine Discussion 10 03-10-2014 09:48:47 AM
Fairbanks-Morse 6 HP Z J.Bubba Lee Antique Gas Engine Discussion 28 07-14-2012 01:02:04 PM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Antique Gas Engine Discussion 4 09-12-2008 11:03:58 AM
Fairbanks Morse in a can Doug Wilson Paint Shop 1 08-21-2002 10:01:20 PM
