I ain't got a "screamin Jimmy"... But if i get one?
this thread has 20 replies and has been viewed 1995 times
Old 10-04-2018, 08:18:03 AM
mschreiber mschreiber is online now
Default I ain't got a "screamin Jimmy"... But if i get one?
This one is interesting. Please comment as I know nothing bout "Detroits".
https://www.ebay.com/itm/Detroit-606...s/302899515058
Old 10-04-2018, 09:13:47 AM
Horse Power at 511's Avatar
Horse Power at 511 Horse Power at 511 is offline
Default Re: I ain't got a "screamin jimmy".... But if i get 1?
Looks like an old fire pump engine Mike. Notice the dual starter contractors up front and the rack solenoid on top of the governor. It will be a screamer all right and probably be a great runner!
The Following User Says Thank You to Horse Power at 511 For This Post:
Old 10-04-2018, 09:24:16 AM
haywaj haywaj is offline
That's a 1967. Excellent engines. this has a Woodward hydraulic governor with a manual vernier speed adjustment. High quality.
The Following User Says Thank You to haywaj For This Post:
Old 10-04-2018, 11:09:12 AM
Default Re: I ain't got a "screamin Jimmy"... But if i get one?
will it run slow? i can't drag it around to shows scareing people oft!
what about that 13000 mike!?
Old 10-04-2018, 11:38:24 AM
miltruck miltruck is offline
Be aware how heavy these things really are. Plus it uses a heat exchanger for cooling so you would need a water supply or convert to a radiator. Maybe for just idling at a show, you could use a 55 gallon tank connected to circulate through the exchanger with no problems. It will most likely wet stack though. With 170 hp @ 1750 rpm it may have smaller injectors than a truck engine which would normally be about 238 hp @ 2100 rpm. Only way to tell accurately is to pull the valve cover and read the numbers. Would do this anyway if you want to buy it.
The Following User Says Thank You to miltruck For This Post:
Old 10-04-2018, 03:19:55 PM
That will run quite slow, around 350 or slow when hot.
Old 10-04-2018, 04:30:04 PM
I agree with miltruck Mike. That engine will run nicely at all speeds but you will see some slobbering and smoke from the exhaust after long periods of idling. Pretty similar to your Cummins. Thatís why I like generators, easy to load up and clear out... Better for them in the long run.
The 13000 is still resting, been working on my Bessemer project. You have to find a good load for your 13000!
Hope you get the Detroit!
Old 10-04-2018, 07:00:07 PM
Junkologist's Avatar
Images: 160
I love a good running Detroit. They just sound like pure power! I have a 2-71 in an Allis-Chalmers HD-5 crawler with a Tractomotive Shovel on it. It doesn’t have enough cylinders to really get screaming, but it does yell pretty loud! Some neighbors of ours used to run a sawmill with an 8V-92. Now, that thing would get your attention when they wound it up! You always knew when they were running the mill.
Looks like a great engine for you, Mike! Go for it!
SmokStak member #146
Old 10-05-2018, 03:43:28 AM
The Diesel Doctor The Diesel Doctor is offline
The option plate shows that you have a model 6061A with a HV7 (type 12) fuel injector. The engine is a standard not (N) and has a two valve cylinder head. If the engine does not have a raw water pump the heat exchanger was cooled by some external pressure water source. If you installed a smaller straight body N injector , there would be less wet stacking. Clean looking power unit. AL
The Following User Says Thank You to The Diesel Doctor For This Post:
Old 10-07-2018, 10:30:33 PM
Norm W Norm W is offline
You can get a HN injector for it. That is a "N" injector in a "HV" body. I did that when I rebuilt a 2 valve 6-71. I went from HV70s to HN55s.
The Following User Says Thank You to Norm W For This Post:
Old 10-08-2018, 08:59:46 AM
That's what I did on my 1945 6-71. Went from HV70s to HN60. Runs very clean.
Old 10-08-2018, 12:51:42 PM
JoeCB JoeCB is offline
Screaming Jimmys Ö ya' I still have vivid recollections of the time that as a young (1965) engineering student at GM here in Detroit we got a tour of the Detroit Diesel Plant here on Telegraph road. The engines lined up in the dyno test cells were most impressive. Running at full bore the sound was "earth shaking" Ö still fondly remember that.
Joe B
The Following 2 Users Say Thank You to JoeCB For This Post:
Need contact info for Jimmy Bell Reed Engine Oil Field Engines & Related Equipment 2 01-13-2018 11:43:49 AM
Jimmy Bell FMZ parts? MotorCraftMan Antique Gas Engine Discussion 4 08-01-2012 09:47:00 AM
"Screamin' Demon" jet turbine John Newman, Jr. Scale Model Engineering 3 11-26-2010 01:55:01 AM
Looking for Jimmy Notnagle LCJudge Antique Gas Engine Discussion 3 03-22-2009 07:08:42 AM
