Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Just don't know about this air cooled...
this thread has 13 replies and has been viewed 4677 times
Old 10-21-2010, 12:30:10 AM
maak maak is offline
Default Just don't know about this air cooled...
i recently acquired this motor, i need some help.
i cant seem to figgure out what it is for sure.
it has no name or number tags. no cast #`s
or stamped #`s .
Name:	what is it 001.jpg
Old 10-21-2010, 12:35:31 AM
Dan Baalman Dan Baalman is offline
Default Re: just don`t know
More pictures might help. Looks like it might be an early motorcycle engine. Any carb or ignition parts with it?
Old 10-21-2010, 12:43:50 PM
Frank17 Frank17 is offline
Looks to ressemble a Smith Motor Wheel...not enough pictures. But i can tell that it is a motorcycle engine of some sorts.
Old 10-31-2010, 07:40:48 PM
Chris J Chris J is offline
Images: 833
Looks close, or possibly just like a 1911 Vintage Excelsior Auto-Cycle built by Excelsior Supply Co. Randolph Street Bridge, Chicago, Ill
Could be off of a different brand, but definatly a motor cycle engine.
Old 07-08-2014, 06:17:25 AM
thanks, i will try and get more pics
---------- Post added at 03:17 AM ---------- Previous post was at 03:13 AM ----------
thanks, i will get more pics
Old 07-08-2014, 12:00:39 PM
Engine Whisperer Engine Whisperer is offline
Defective Email Address
Default Re: Just don't know about this air cooled...
Whatever brand this is hasn't been mentioned yet. I do not know what it is but I don't think it is as early as the design suggests. The end of the crankshaft is speaking to me, I just can't hear what it's saying. It has flat spots milled off with a hole through the milled area, not threaded on the end to hold a pulley or sprocket. Looking forward to seeing some pics of the other side.
---------- Post added at 11:00 AM ---------- Previous post was at 10:56 AM ----------
Holy Cow maak, just noticed, almost 4 years between posts?
The Following User Says Thank You to Engine Whisperer For This Post:
Old 07-08-2014, 04:16:53 PM
HBurk HBurk is offline
maak ain't in a hurry. Don't rush him.
The Following 2 Users Say Thank You to HBurk For This Post:
Old 12-20-2010, 08:33:23 PM
abriggsman abriggsman is offline
If im not mistaken that appears to be an early harley davidson single cylinder cycle engine. Possibly250-500cc
But I could be wrong. Its hard to tell without actually seeing
it on person. I would check with vintage Harley Collectors first
to get a positive ID on that engine.That would Be your best start . Good luck to you
Old 12-20-2010, 09:40:25 PM
speleausmining
There was a thread like this a little while ago, I think the concesus was that its a motorcycle engine. I dont know what brand or even if the brand was identified. but then engine in that thead was almost identical.
Old 07-08-2014, 11:28:14 PM
SteamfanMN SteamfanMN is offline
I'm no expert by any means but I am convinced this is not a Harley as they had a external rocker arm and they had their name embossed on the bottom of the crankcase and a serial number at the top of the crankcase where the cylinder met and there was also a number on the base of the cylinder too. Also with Harley's they had a magneto this one appears to have a battery and coil system since I don't see a bracket for one.
Could be a lesser known maker, most older big names had their names embossed on it somehow.
Associated 3/4 hp air cooled Roger Kirschenman Small Air Cooled Gasoline Engines 19 05-31-2006 10:44:56 PM
Associated Air Cooled TomT Antique Gas Engine Discussion 2 08-26-2005 08:45:56 PM
Air cooled mag. Arthur Antique Gas Engine Discussion 0 08-25-2005 10:58:05 PM
Associated air cooled wade white Antique Engine Archives 2 10-27-2003 09:54:51 PM
Air cooled vs. water cooled Bill in PA Antique Engine Archives 5 11-18-2001 01:20:50 AM
