Wisconsin Engines
Wisconsin-Robin EY27W Power curve???
this thread has 1 replies and has been viewed 10322 times
Old 11-23-2005, 06:10:16 PM
Stans Stans is offline
Default Wisconsin-Robin EY27W Power curve???
I"ve a Wisonsin Robin EY27W which is rated at 7.9hp @ 3600rpm or 4.9 hp @ 1800 rpm. I would like to run a generator head which requires 3600 rpm, at the 1800rpm engine speed, however this wouldn't be feasible if the engine's torque was low at this speed. Does anyone know where I might find the info on the power curve of this engine so I can get the best sized pulley to take advantage of the lowest feasible speed?
Stan
Old 11-24-2005, 02:17:50 AM
Exclamation Re: Wisconsin-Robin EY27W Power curve???
Contact a Wisconson dealer, they should be able to give you a spec sheet on the robin.
Andrew
Robin Generator Bill Sherlock Generators & Electric Motors General Discussion 6 01-15-2019 11:49:58 AM
Robin EC10 Chris Kirk Small Air Cooled Gasoline Engines 4 10-13-2010 01:04:13 PM
new member welcome Robin F BDMelon Antique Gas Engine Discussion 3 07-23-2007 09:33:46 AM
Wisconsin TH with US Light Power 5.5kw genset Shootist357 Generators & Electric Motors General Discussion 9 01-01-2006 04:48:28 AM
Robin RGX3500 brushless chuck Generators & Electric Motors General Discussion 2 12-16-2002 02:45:56 PM
