Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Maytag Engine Collectibles
Maytag 92 crank bushes
this thread has 1 replies and has been viewed 804 times
Old 08-13-2016, 06:14:11 AM
livram40 livram40 is offline
Default Maytag 92 crank bushes
With being new to Maytag ownership am in need of expert advice, I fired up my model 92 for first time earlier in week, it was bought as a box of large lumps, engine main part was complete but things like flywheel, gas tank, kick start were in a box of items.
As said fired for first time but see fuel is seeping from both sides am taking it the crank bushes are u/s, I know these bushes are available on ebay but would it be ok to fit new items to existing crank case or does the 2 parts need to be mated, in other words can I put a used crank into new bushes for it to be ok to use.
Any advice welcome, thank you.
Old 08-13-2016, 08:19:49 AM
Clement Rook Jr. Clement Rook Jr. is online now
Default Re: Maytag 92 crank bushes
livram40,press the old bushings out of the crankcase,press in the new ones and ream to fit your crankshaft .or better yet if you or your machine shop has a sunnen hone ,have them honed to fit your crank.this usually gives a better fit than reaming.
The Following User Says Thank You to Clement Rook Jr. For This Post:
Maytag 92 crank bushes Jonesey Maytag Engine Collectibles 2 07-01-2015 07:49:23 PM
Grease lubricated bushes pjjms Antique Gas Engine Discussion 1 01-03-2012 05:18:41 AM
Marquette welder exciter bushes Joseph Welding Shop 3 01-25-2009 08:43:39 PM
Maytag vertical crank Dustin D Ehli Antique Gas Engine Discussion 2 05-02-2007 08:13:58 AM
Generator Bushes. DP9101 Generators & Electric Motors General Discussion 1 10-17-2005 12:20:20 PM
