Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Maytag Engine Collectibles
Maytag 1946 72 twin connecting rods and caps needed
this thread has 3 replies and has been viewed 930 times
Old 08-07-2016, 08:02:08 AM
stitchwizzard's Avatar
stitchwizzard stitchwizzard is offline
Default Maytag 1946 72 twin connecting rods and caps needed
Hi,
My husband decided to tear down and rebuild our 72 twin. Ours developed a loud knocking noise all of a sudden while test running the motor. After tear down and inspection, My husband found that someone had previously replaced the rod screws with socket head cap screws with no lock washers. The SHCS's backed out and tore up the rods and caps. Does anyone have a good set that they would be willing to part with? We do have good pistons and new rings. Please message or email me!
Thanks again everyone!
Stitch
Old 08-08-2016, 11:32:42 AM
Exclamation Re: Maytag 1946 72 twin connecting rods and caps needed
You might try contacting Tom S or Mark Shulaw, the Maytag gurus, here on the Stak. There is also several maytag parts suppliers on Evilbay and on the internet. Check also here on the Stak Sponsor pages. the Maytag bronze rods are not very forgiving. Make sure to use either SAE 30 NON-detergent or a good TCW-3 OIL for lubrication, at the proper ratio - 16:1 1 cup oil to 1 US gallon gas. Use high test gas, to help prevent alky issues and fuel degradation. Hope you can find a good set of rods.
Andrew
Old 08-08-2016, 10:53:19 PM
Default Re: Maytag 1946 72 twin connecting rods and caps needed
Stitch, there's a pair on eBay now with the Pistons. Missing two of the end caps but looks like a good deal for the $.
Kevin
The Following User Says Thank You to Kevin Weis For This Post:
Old 08-14-2016, 06:07:28 AM
Thank you Kevin! A really nice member sent me two rods and they worked perfect!! Engine is all assembled and ready for the test run today.
Thank you all!
Stitch
What engines are these connecting rods from? BigGoomba Antique Gas Engine Discussion 3 05-18-2016 09:16:04 PM
Help identify old GM connecting rods Jeff Blaney Antique Autos and Trucks 5 09-16-2012 06:44:05 AM
Connecting Rods Jack Innes Antique Farm Tractors 6 10-07-2011 09:23:32 PM
Connecting Rods Jack Innes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-06-2011 10:48:04 PM
Can Anyone ID These Bronze Connecting Rods? Chris Lewis Antique Gas Engine Discussion 5 01-19-2008 07:26:17 PM
