How do you Identify Detroit Diesels?
this thread has 15 replies and has been viewed 1250 times
Old 04-28-2018, 07:26:01 PM
Default Re: How do you Identify Detroit Diesels?
My first thought, was on a quiet night after the storms or hurricane or earthquake or nuclear holocaust has knocked out all the power, listen for the roar that sounds like someone tied a semi truck wide open and it's ready to spit out it's crankshaft, and you will likely find a Detroit at the source. Or listen for the last running engine on the planet
As for the smoke, at least in power generation, I've found Detroits to make a lot less smoke then most other engines of their time period.
Old 04-28-2018, 07:28:50 PM
John Schwiebert John Schwiebert is offline
The restriction is a fitting that screws into the head. The return line is not the restriction
Old 04-28-2018, 11:18:25 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
We was always told how to ID one in a truck was to look under the front, if there was a oil puddle under it, You had a Detroit! "If there ain't any oil under it, there ain't any oil in it!"
Old 04-29-2018, 08:48:22 AM
Tracy T Tracy T is online now
ok we will see if its a bear to start next time which should be some time this week, if it fires right off i am not going any deeper. i personally think it runs out of fuel @ 1/4 tank of fuel and we spent the first day fighting air in the system and ran down the battery. the poor thing need worked from time to time, when they get done with it they will park it and forget all about it until they need it again which may be years down the road. this is my first dealing with a older detroit, and to be honest i am starting to like them!
Old 04-29-2018, 09:19:10 AM
ronm ronm is offline
You do realize the GM Co. came up with the design shortly after the Roswell UFO incident, right? Proof of alien technology? You be the judge. . .
Smokstak member #442
Old 04-29-2018, 10:32:15 AM
alien technology..... well if so they are some pretty cool aliens!
1905| The Detroit River. "Transfer steamer Detroit in the ice" GarysToys Steam Stationary Engines, Traction Engines, Steam Boats 2 02-10-2016 01:12:52 AM
Looking for Old Cummins Diesels byteboy Military MEP and Aircraft Gen-Sets 3 04-26-2010 07:45:25 PM
Lister Diesels Fred Van Hook Vintage Diesel and Oil Engines 4 07-22-2009 05:37:06 PM
Detroit Moto-Mower, Super Detroit Jim Bracken Small Air Cooled Gasoline Engines 21 06-27-2009 02:00:47 PM
Hundested Diesels? Doug Waggonner Vintage Diesel and Oil Engines 11 09-21-2007 10:23:41 PM
