Daewoo DW20 Genset Parts Sourcing Problem
this thread has 1 replies and has been viewed 468 times
Old 06-26-2018, 01:37:45 PM
Walleyed Walleyed is offline
Default Daewoo DW20 Genset Parts Sourcing Problem
I have a 1999 Daewoo (now part of Doosan) DW20 genset, powered by a Daewoo DC24 2.4L, 4 cylinder diesel. Pulled it out of a barn at the family farm in MI and brought it out to NJ. 91 hours on the hourmeter.
My problem is that within a minute or 2 of startup, it shutdowns with a overtemp coolant fault. I pull the wire off the temp switch on the thermostat housing and she runs just fine.
Unfortunately, I'm completely unable to source a replacement switch (Daewoo DW 67.27441-6002).
It's a M14 thread, I figuring I can probably use a generic switch that's correctly threaded, but I need to know what would be the appropriate switch temperature for the automatic shutdown.
Any thoughts?
Thanks.
Old 06-27-2018, 05:24:51 AM
autosparkii autosparkii is offline
Default Re: Daewoo DW20 Genset Parts Sourcing Problem
At a guess, I'd go for 30 degrees Celsius past thermostat temperature.
Maybe you would want a lower temp.
It is probably a bimetal Thermofan switch.
But used for shut Down Instead of activating a fan.
Daewoo Forklift - Lift Cylinder Repair dalmatiangirl61 Lifting and Loading 32 04-01-2018 10:53:36 PM
Sourcing an old small engine WilmRRMus Small Air Cooled Gasoline Engines 0 08-26-2016 01:16:32 PM
Onan 15.0 MDJF - need help sourcing relays... nukeguy Onan Generators 22 02-26-2016 05:07:53 PM
Markon LC32B alternator - help sourcing spares? miketubby Generators & Electric Motors General Discussion 1 01-26-2015 08:10:27 PM
Onan LPG Genset problem B.Sparks Generators & Electric Motors General Discussion 10 07-22-2008 01:36:37 PM
