Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Engines > Lister Engines
Lister Engines Lister low speed engines both new and old.
Lister Engines
LIster LT1 Questions
this thread has 7 replies and has been viewed 411 times
Old 12-27-2018, 05:43:36 PM
bowtie67 bowtie67 is offline
Default LIster LT1 Questions
I just obtained a Lister LT1 single cylinder engine. It's complete except for a fuel tank. I have a question about a broken plastic fitting located just above the ID tag. Is that a crankcase breather? Where can I get something to replace it?
Also, it seems to have very little compression.
Serial number 07687LT128-09 Any idea it's age? Any help appreciated
ID:	325237   Click image for larger version
ID:	325238   Click image for larger version
Old 12-27-2018, 11:16:16 PM
K-Tron K-Tron is online now
Default Re: LIster LT1 Questions
It looks like the decompression lever on the side of the head is in the full decompression location. Simply turn that decompression valve handle down and it should have enough compression that you cannot crank the engine by hand slowly. You may have to pull the valve cover and check the adjustment on the decompressor. The threaded set screw can back out if the proper retaining nut is not installed. I do not see the broken plastic fuel fitting that you are referring to. All of the Listers I have worked on had brass banjo type fittings for the fuel system. Your engine was built in 1978. 1950 +28 (last two numbers in the serial number) = 1978
Old 12-28-2018, 09:21:54 AM
S Mullins S Mullins is offline
thats the primer plug for cold start probably,its for a little oil right in the intake. works great.
You may only have a little carbon under a valve seat,mine will do that when they sit a long time.
Old 12-28-2018, 01:06:46 PM
Thanks for your replies. Here are several more pictures of the LT1. It appears to be a gear reduction and at some point someone added a Delco starter generator.
The compression release lever has no resistance when moved.
The one picture, clearly shows the remains of the plastic cold start device on top by the valve cover. I think it can be eliminated if I can't find a replacement.
Any help with parts appreciated.
ID:	325277   Click image for larger version
ID:	325278   Click image for larger version
ID:	325279   Click image for larger version
Old 12-28-2018, 04:24:45 PM
The "gear reduction" is actually the extended camshaft. That is where the hand crank goes for ease of starting the engine. Now I see the busted off fuel primer cap. You can simply put a piece of tape over it, or tap it and install a pipe plug. If you feel no resistance when moving the decompression lever, either the exhaust valve is already down, or the decompressor lever needs to be adjusted. You will have to remove the valve cover to do so. It could be as simple as turning a small nut back and forth, or could be a more difficult repair. The engine can certainly have no compression if a valve is stuck in the open position. If that is the case, penetrating oil and time is your best friend. After enough soaking you can try sticking a flat head screwdriver between the spring turns and see if you can manually pull the valve up. Let us know what you find, those LT1's are great engines.
Old 12-28-2018, 06:40:08 PM
Chris, Thanks for your reply. I removed the valve cover to see the decompression lever adjusting bolt. The lever has to be pulled outward and then rotated down to a vertical position to engage the decompression bolt with the rocker arm. After start-up, the lever must be rotated back up between the two "tabs" to hold it in neutral position.
After seeing how the decompression lever works, I tried it in both on and off positions. I now have compression.
I'm going to try and rig up a remote fuel tank and clean up the starter generator and try to get it running.
Are there any parts dealers in the midwest area?
Thanks for your help.
Forgot to ask.....anyone have a crank handle for starting a LT1?
Old 12-28-2018, 10:43:56 PM
Combustor Combustor is offline
Hello Bowtie67,
The North American distributor for all Lister products is located in Lyons, Kansas and may be contacted via gary@dieselgen.com Very helpful people and will likely have the parts you need. Regards,
Combustor.
Old 12-29-2018, 11:47:46 AM
Lister hand cranks are surprisingly difficult to find in the USA. It took me almost a year to find one for an SR, and that fits a larger camshaft than the LTs. If Gary does not have the parts, you might get lucky buying them from different sellers on ebay in the UK. I have had to do that on several occasions, as parts were not available here.
Lister SL2 questions stevo42 Vintage Diesel and Oil Engines 27 10-23-2014 08:43:16 AM
Lister SR2 questions scoops Vintage Diesel and Oil Engines 44 08-31-2013 10:00:47 PM
Lister new bee with questions Mike7.62 Vintage Diesel and Oil Engines 16 09-26-2010 09:32:58 PM
Pics and questions on my new Lister ST2 16/2 JB740i Vintage Diesel and Oil Engines 14 03-24-2010 10:22:08 PM
Lister Questions CatMan Vintage Diesel and Oil Engines 4 06-06-2009 07:54:03 PM
