Oil Field Engines
Cast from the past - Oilfield
this thread has 66 replies and has been viewed 18197 times
Old 03-17-2012, 08:40:33 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Photo Re: Cast from the Past - 15hp Pattin
Tom , I think is all there. Several stray pieces piled up beside the engines. What bedplate do you have? I may have extras. This is a Oil City steam with some trinkets you might need ???
Name:	nov 19 2910 288.jpg
Skidmore aka engine hoarder
Old 04-14-2012, 11:08:40 PM
Skidmore's Avatar
Pulled this nice old 20 Pattin out of a bamboo patch today. A fellow Stacker pulled this off the well site a few years back. Should be a nice runner not stuck and comes with the matching brass tag #1971. Thanks Myles
Name:	april 14 2012 007.jpg
ID:	133158   Click image for larger version
Name:	april 14 2012 001.jpg
The Following 4 Users Say Thank You to Skidmore For This Post:
  #23
Old 04-15-2012, 04:30:26 AM
Question Re: Cast from the Past - 15hp Pattin
Looking good! Bet it has a real loud bark, with that short exhaust! Was the hot tube assembly with it, or do you have to make one up?
Old 04-15-2012, 08:29:43 AM
Skidmore's Avatar
Default Re: Cast from the Past - 15hp Pattin
Looks like the hot tube bushing was broke off a good while back. Need to get with John Burns for some top knotch replacement parts.
Old 04-19-2012, 09:16:01 PM
Skidmore's Avatar
Check out this engine failure and the repair, This would make a great engine show display. I would say the cylinder was tooo heavy, needed some support. Cylinder looks good on the outside may try to save it from the junkers.
Name:	April 2012 030.jpg
ID:	133486   Click image for larger version
Name:	April 2012 027.jpg
  #26
Old 04-22-2012, 09:52:31 AM
Skidmore's Avatar
Looks like the cylinder laid where she fell. No cracks but the exhaust was up like a funnel for years. Looks to be a 20hp Oil Well Supply. True halfbreed did anyone notice the Reid flywheels.
Name:	april 2012 016.jpg
The Following 2 Users Say Thank You to Skidmore For This Post:
  #27
Old 06-18-2012, 07:51:52 PM
Skidmore's Avatar
Photo Re: Cast from the past - Oilfield
Found this big Bessemer in the wild last week. Don't know what Hp it is, but the crank measures 4 1/2". Still has the valve and ecentric for the mag, cylinder not cracked but stuck and missing the connecting rod & brass.
Name:	june 2012 009.jpg
  #28
Old 06-18-2012, 09:45:26 PM
JIMnWV JIMnWV is offline
eMail NOT Working
Default Re: Cast from the past - Oilfield
Be nice to drag that one out, Gives me food for thought.......I have a 48 inch by 10 inch flatbelt pulley I was thinking of putting on my 20hp bessemer,...I might as well it too has the stub shaft on the crank. Keep hunting Skidmore.....leave no stones unturned
Jim
The Following User Says Thank You to JIMnWV For This Post:
  #29
Old 07-07-2012, 04:46:24 PM
Nickboy90 Nickboy90 is offline
Hey Skidmore, is that Struthers-Wells still there? I'm from Warren and have been looking for one...
Old 07-07-2012, 06:23:35 PM
Skidmore's Avatar
Struther Wells is gone It's at my place now
Broken Sub Base: Mold, Cast, Cast Iron Weld DaveTexas Antique Gas Engine Discussion 24 03-17-2011 12:00:46 AM
Stickney Cast Iron Seat Do You Need One Cast? Marshal Reysen Antique Gas Engine Discussion 5 04-08-2010 01:22:44 PM
Stickney Cast Iron Seat Cast? Craig A Antique Gas Engine Discussion 0 01-22-2010 09:01:44 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
Is there someone that can cast - cast iron near me? Ron Weber Antique Gas Engine Discussion 1 07-06-2008 03:45:22 PM
