Oil Field Engines
Cast from the past - Oilfield
this thread has 66 replies and has been viewed 18196 times
Old 07-07-2012, 07:06:09 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Photo Re: Cast from the past - Oilfield
Pulled some old Iron out today, Sure was hot - 97 in the shade. South Penn halfbreed not much left . Lots of nice artifacts laying around & no snakes this time. Really got it for the steam flywheels and crank.
Name:	july 2012 012.jpg
ID:	139185   Click image for larger version
Name:	july 2012 006.jpg
Skidmore aka engine hoarder
Old 07-08-2012, 04:08:18 PM
jochemhanomag jochemhanomag is offline
Default Re: Cast from the past - Oilfield
hello
its almost onbelieveble waht you find in the woods
I would like finding some like that stuff
but there are a lot of engine without conection rod
is that to make the engine unusefull fore oder people ??
Regarts Jochem
Old 07-08-2012, 07:19:00 PM
Skidmore's Avatar
I think as these wells petered out they removed parts from another engine to keep a better well producing. Old timers said the old halfbreeds really got ran ragged toward the end. In hopes of getting a new Reid to take its place.
Old 09-01-2012, 08:21:45 AM
Skidmore's Avatar
Saved this nice 15hp Ball from going to China for scrap. Engine was hauled in with oilers and brass tag which we removed before they came up missing. Looks to be a nice engine but for some reason the head was removed. We found the the oil Co. that brought it in and the head and some other artifacts were in the bed of the truck.
Name:	Portland 2012 025.jpg
ID:	143809   Click image for larger version
Name:	Portland 2012 026.jpg
The Following 9 Users Say Thank You to Skidmore For This Post:
  #35
Old 09-01-2012, 12:15:02 PM
Rod Fielder Rod Fielder is offline
did ya find a walking beam jack for coolspring??? even the cast parts would be enough for me to build the rest!
Old 09-01-2012, 02:57:39 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Thats just plain awsome, I just gotta get me one of those. Don't see that stuff around here. F.J.W.
Old 11-03-2012, 08:53:08 PM
Skidmore's Avatar
Checked on some engine leads today. The first photo is a bad sign,Wood engine block in middle of the road. and no engine Rod must have been there a few days earlier Did see a few treasures, check out the band wheel brace / connecting rod. what ever works use it.
Name:	nov 3 2012 002.jpg
ID:	148530   Click image for larger version
Name:	nov 3 2012 001.jpg
The Following User Says Thank You to Skidmore For This Post:
  #38
Old 11-08-2012, 08:58:17 AM
Skidmore's Avatar
Brought in a heavy weight the other day. 25hp Script Reid, We had to take it out piece at a time due to where it was at. Should be a nice runner. Was complete when we spotted it ,but the oilers and main valve came up missing before we found out the Oil Co. that owned it.
Name:	Engine gathering 155.jpg
ID:	148973   Click image for larger version
Name:	Engine gathering 157.jpg
ID:	148974   Click image for larger version
Name:	Engine gathering 153.jpg
ID:	148975   Click image for larger version
Name:	Engine gathering 150.jpg
The Following 6 Users Say Thank You to Skidmore For This Post:
  #39
Old 11-09-2012, 09:10:41 PM
Zach Williams's Avatar
Zach Williams Zach Williams is offline
Email Not Working
That is a good looking engine.
It seems there are sticky fingers in the area though....
I can't count how many engines we have found and then come back with shiny bearings showing! Seems like if you find them then some jerk does as well.
However oilers are cheap i suppose.
Congrats on the find!
Old 11-09-2012, 09:47:59 PM
i just sold a set of 25 reid cast iron oilers.
The Following User Says Thank You to Rod Fielder For This Post:
Broken Sub Base: Mold, Cast, Cast Iron Weld DaveTexas Antique Gas Engine Discussion 24 03-17-2011 12:00:46 AM
Stickney Cast Iron Seat Do You Need One Cast? Marshal Reysen Antique Gas Engine Discussion 5 04-08-2010 01:22:44 PM
Stickney Cast Iron Seat Cast? Craig A Antique Gas Engine Discussion 0 01-22-2010 09:01:44 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
Is there someone that can cast - cast iron near me? Ron Weber Antique Gas Engine Discussion 1 07-06-2008 03:45:22 PM
