Steam Engines
Curved Spoke Flywheels and Single Rivet Laps
this thread has 15 replies and has been viewed 3309 times
Old 04-10-2012, 02:28:51 PM
Steamrguy's Avatar
Steamrguy Steamrguy is offline
Default Curved Spoke Flywheels and Single Rivet Laps
So… when did most companies shy away from using curved spoke flywheels and single rivet lap joints? There are other features on both boilers and engines that identify them as “OLD”. A lot of the really old stuff is difficult to date. It would be interesting to add this time line to our growing pool of information.
-Dean-
Old 04-10-2012, 04:21:01 PM
Joe K Joe K is offline
Default Re: Curve spoke flywheels and Single rivet laps
Ooh. Tough question to nail down definitively. Especially the first.
Well, one opinion of many, having taken note and observed these things over many years of my life.
Curved spoke pulleys probably started going out in the 1880s. By then everyone had had developed enough confidence to be able to cast something with straight spokes and have some assurance cracks would not occur - nor develop in actual use.
But this did not happen all at once or a result of any accident - or lack thereof. More likely the old patterns wore out and when new ones were made they said "lets try it like this" - and the this being straight spokes.
Single lap rived boilers never really went out. Qualify that - they never really went out but certain jurisdictions took upon themselves to look with a jaundiced eye - which I don't really understand.
And part of this jaundice was promoted by the ASME itself who effectively "outlawed" single lap rivets above 100 psi. Which others, correctly I might add, have opined was an extreme overreaction. And not universally followed even among boiler builders.
I myself own a single lap seam boiler which, if memory serves, I calculated out at an operating pressure of 210 psi - and this limited by the stamp to 100 psi - and this even on a non-code boiler built in 1907 - the 100 psi ASME limit taking some credence by this builder even before it's 1910 adoption. (I think I'm remember this right.) But this Lookout Boiler is very much built like a proverbial "brick sh*t house" with 3/8" plates and 3/4" rivets (I think - hard to tell this latter.)
Lookout and the few others that survived into the mid-20th century continued to build a single lap seam boiler - but limited to 100 psi. Although many did change their construction techniques to included welded construction - the firebox and ogee ring being one area.
One midwest seller of a small boiler on Craiglist (and referenced on this site) indicated (IIRC) "single lap seam, welded fire-ring, 100 psi, Code Stamped 1947. Probably the last of its kind though.
The spoke/flywheel thing did concern the Henry Ford Museum enough in the 1980s to "take down" the entire overhead pulley works in the Edison Brick Shop and have everything sandblasted and dye-penetrant checked for cracks and then repainted - to include the flywheel on the Greene Engine - which in my opinion was probably of the greatest risk - being the largest diameter. But risk is more a function of the square of the velocity - which I don't have data on for the rest of their pulley/belting systems.
At the same time the B&W boiler was examined in detail similarly and pronounced "fit" according to the literature.
I did not hear of any issues that were found or corrected - but maybe this examination was required by their insurers - this being a public display. And the article despite the potentially dire import was decided "upbeat" - as you might expect.
Curious a couple of years back when the family and I were out to "The Henry Ford" (as they like to be called) we were at Edison's Laboratory from Ft. Myers and outside on the ground was the hulk of a B&W boiler - not sure why there. Kept as a spare or possibly a reject from that examination?
Both (all actually) interesting subjects to a 19th century man being held captive in the 21st century.
Joe
The Following 3 Users Say Thank You to Joe K For This Post:
Old 04-10-2012, 09:01:35 PM
Exclamation Re: Curve spoke flywheels and Single rivet laps
Gaar-Scott used curved spoke flywheels on at least their 13 HP engines until 1912. Nichols & Shepard used them until the bitter end-the late 1920's. Didn't Port Huron use them until the end, also?
Frick used single-row lapseams until at least the teens on their 12 HP tractions.
It takes more than either a single-row lap or a curved spoke flywheel to neccesarily denote an old engine. I've seen plenty of engines built in the 1890's that had single-row laps, but straight spoke flywheels. I've also seen numerous curved spoke flywheel engines built quite late, too.
Mike M
The Following 2 Users Say Thank You to Mike McKnight For This Post:
Old 04-10-2012, 09:27:08 PM
Beth V's Avatar
Beth V Beth V is offline
My 1917 24 Port Huron has a curved flywheel. Some of the early Port Hurons had straight spoked flywheels.
Beth
The Following User Says Thank You to Beth V For This Post:
Old 04-11-2012, 07:44:29 AM
Tom Runty Tom Runty is offline
The 19 Port Hurons had curved spokes - but we tell people that they used to be straight!
Nichols & Shepard used curves spokes as well.
The Following 3 Users Say Thank You to Tom Runty For This Post:
Old 04-11-2012, 07:56:39 AM
David's Avatar
David David is offline
Geiser used curved spokes on all their traction engines except for the Anderson models, and Emerson-Brantingham continued the style after they acquired the Geiser line.
Geiser portables also used the curved spoke flywheel up to at least 1905, and perhaps later. Mike Rohrer would know more about how long this design lasted on the portables.
David
The Following User Says Thank You to David For This Post:
Old 04-11-2012, 08:39:44 AM
Correction on that Edison Brick Shop engine: The engine was a Brown Engine from Fitchburg, MA. The Greene Engine is at NEWSM and is a product of Rhode Island.
I guess you could say I'm color blind. Black & white works.
Joe
Old 04-11-2012, 10:13:54 AM
Jack Hottel Jack Hottel is offline
David
Geiser continued the curved spokes as long as they built the letter series Landis type engines. The 40/50 Landis types have straight spokes.
It is interesting to look at the 1918 catalog cuts of these
last. They are modifications to the earlier cuts and don't have the details right.
Jack Hottel
The Following 4 Users Say Thank You to Jack Hottel For This Post:
Old 04-11-2012, 10:33:57 AM
Images: 2716
Some earlier Aultman-Taylors had straight spoke flywheels.
Most early Aultman-Taylors used "dog leg" flywheels.
Otherwise, it would appear they used the dog leg flywheels to the end. Gary
The Following 2 Users Say Thank You to 20 Reeves Highwheeler For This Post:
Old 04-11-2012, 10:40:48 AM
Peter Peter is offline
I believe that Aultman Taylor straw burner flywheel was a probable replacement. Nothing I can prove, but seemed a concensus of some of us at one point.
The Following 2 Users Say Thank You to Peter For This Post:
1903 Curved Dash Oldsmobile paulbrook Antique Autos and Trucks 14 06-26-2011 10:20:58 PM
Curved spoke flywheels (cost?) 26" to ~40" jim day Unidentified Engines 3 11-05-2009 07:36:36 AM
Curved Spoke Flywheel Drawings oscar Scale Model Engineering 3 07-10-2009 03:44:24 PM
Curved Spoke Flywheel Tom Guinn Antique Gas Engine Discussion 14 06-02-2009 09:29:46 PM
Rivet Gun Help John Deck Steam Stationary Engines, Traction Engines, Steam Boats 13 01-04-2007 09:09:47 PM
