G204 rectifier/regulator change Wisconsin to Kohler
this thread has 2 replies and has been viewed 2819 times
Old 06-19-2012, 09:22:12 AM
spocter72 spocter72 is offline
Default G204 rectifier/regulator change Wisconsin to Kohler
I have a older G204 Hobart welder with a 4 cyl. Wisconsin Engine. I am trying to replace my Wisconsin rectifier and regulator with a Kohler rectifier/regulator combo unit PN 41-403-09. My stator has 2 AC wires plus a red wire that went to the original regulator. Kohler reg/rec has connections marked "AC +B AC". I realize the AC wires go to AC connections and I'm pretty sure "+B" goes to ammeter/battery, but not sure where the red wire would go. Could anyone please lead me in the right direction or a link or a schematic to the proper way to wire this? Thank you so very much in advance
Old 03-28-2014, 08:42:55 AM
rlfervan rlfervan is offline
Default Re: G204 rectifier/regulator change Wisconsin to Kohler
were you able to figure this out? I have the same situation.
Old 03-28-2014, 11:18:24 AM
Richard L Richard L is offline
Call Brian Clugson at Flight systems he is great at what he does, should be able to help.
R
How To Test Kohler Rectifier? DaveHC Small Air Cooled Gasoline Engines 21 05-13-2017 09:36:12 AM
Generic 15a Rectifier/Regulator for 12kw generator mojonba Generators & Electric Motors General Discussion 5 09-15-2010 04:55:46 PM
Kohler #30r72 25kw 3ph Change Taps? mytickets Kohler Generators 7 03-05-2010 05:28:34 PM
MEP-003 Battery Rectifier Regulator Schematic JimThescot989 Military MEP and Aircraft Gen-Sets 1 12-29-2008 02:45:34 PM
Un-Official Wisconsin Page Address Change Zira Wisconsin Engines 2 05-07-2008 10:04:40 PM
