Maytag Model 92 Carburetor test tool
this thread has 12 replies and has been viewed 4431 times
Old 08-24-2012, 10:01:15 PM
Gampy Gampy is offline
Photo Maytag Model 92 Carburetor test tool
I recently bought this tool along with a number of others from a Texas Maytag enthusiast.
He told me that you press the white knob at the bottom while pressing the rubber stopper into the air intake. If it holds a vacuum for 4 seconds then leave the carburetor alone.
I am wondering if anyone has seen this tool before or has had any experience with it. If so, do you agree with my description of how to work it?
Name:	2012-08-24 17.04.11.jpg
ID:	143266   Click image for larger version
Name:	2012-08-24 17.03.59.jpg
ID:	143267   Click image for larger version
Name:	2012-08-24 17.05.18.jpg
The Following User Says Thank You to Gampy For This Post:
Old 08-26-2012, 10:21:38 PM
Mark Shulaw Mark Shulaw is offline
Default Re: Maytag Model 92 Carburetor test tool
Never seen that tool or had a need for it. But it is obvious as to its purpose. Its to test to see if there are any leaks with an assembled carburetor. Testing for leaks is a debate-able idea for a rebuilt Maytag carburetor. As to using this as an end all be all of carb testing its not going to tell you about wear to the internals unless the wear is severe enough that the valve leaks or there is a crack somewhere that leaks. Or for flow and atomization characteristics. I have rebuilt these carbs for many years and never had a use for or even dreamed of having a use for a tool like it. And as a aide for the occasional rebuilder I am not sure what it would help with. If you are looking for a tool to detect faults with a carb, by the time you learn what the tool is telling you, you can just as easily tear down and inspect. They are not that complicated. One tool I have dreamed of having just for the fun of it is a flow tester. Its need for use would be slightly more. Still gimmicky for a Maytag carb but more interesting. Mark
Old 08-26-2012, 10:43:56 PM
I agree, the 92 carb is very simple and I have not needed the tool. Perhaps it may have been used (in the day) by the friendly Maytag Repair man as a quick diagnostic tool.
After all I don't know the origin of the lonely Maytag Repair Man, but this tool may have contributed to his being lonely. Not too much time spent on the job. Just stick a guage on it and get on back to being lonely.
Old 08-26-2012, 11:51:20 PM
No test tools in the tool list. Mark
Old 09-20-2012, 09:18:39 PM
Marvin McCullough Marvin McCullough is offline
I must be missing something about the purpose of this tool. How could you pull a vacuum at the air inlet of the carb since there is a breather tube in the back of the carb housing that vents the fuel tank. You would have to have a completely sealed tank and a perfect gasket seal at base of carb. Even the fuel fill cap has vent hole in it. It could only pull a vacuum if the carb is off the engine base and the the breather tube is plugged.
Old 09-20-2012, 10:17:17 PM
sprkplug sprkplug is offline
Banned
I'm not very knowledgeable when it comes to Maytag engines, but if it were me, I believe I would hold tight to that tool until such time as more information becomes available. Perhaps it was assembled by an inventive type, out of spare parts he had laying around, and was never produced by the factory....the Maytag script on the guage notwithstanding. As such, it may never become worth more than whatever you may have paid for it.
Or maybe, it was a short-lived, genuine Maytag article, of very limited production. The zip ties hint at a more modern birthright, or at least a recent improvement to the original design, but who knows for sure? The Maytag aficianados who are sure that their stock of knowledge is infallible? Maybe, but if it were possible to somehow prove that your tool is what it seems to be, then irregardless of how well it may have worked, or even if it didn't live up to the factory's expectations, then those same enthusiasts will probably bemoan the fact that THEY can't find one to add to their personal collections......
Either way, the place to start would appear to be the collector you acquired it from.
Yeah, since it's not costing you anything to feed it, I think if it were me I'd set it up on a shelf for awhile...
Old 09-20-2012, 11:07:28 PM
The zip ties were put on by me. I also replaced the rubber tube and the metal tube. The tip on the end is one of two sizes that are original. I also kept the original rubber and metal tubes. I duplicated their size and length. The original ones had some kind of sticky glue stuff on them. The other end "stopper" with a hole in the center is the larger of the two sizes. I wanted to see what it did and how it might work and the originals seemed to leak. I was told to close the needle valve before testing?
Working or not, it's Maytag and it's a cool thing
Old 09-21-2012, 07:26:54 AM
Banned
Exactly...
Old 09-21-2012, 11:06:51 AM
bigGURN's Avatar
bigGURN bigGURN is offline
Images: 1
Looking at the gauge the Maytag script almost appears as if it was applied there by someone else (just too bright to match the faded back ground) I have several vintage gauge sets for other pieces of equipment and irregardless of who made the gauge the manufacturer's name (of the product utilizing the gauge) is always printed on the back ground, not applied as a cut out as in yours. Not that I am discrediting the gauge as genuine maytag, but it does appear to perhaps open the door which would lend to it having been created by some rather intuitive individual...
Old 09-21-2012, 03:45:39 PM
Andrew Mackey Andrew Mackey is online now
Exclamation Re: Maytag Model 92 Carburetor test tool
I would suggest that it probably would be used to test the entire crankcase/ intake system. If you have poor bearing fit, bad gaskets or poor ring seal, you will loose crankcase/intake vacuum pretty quickly. Eventually the tank vent will drain what vacuum remains after you stop turning the engine, and if the piston uncovers the exhaust port, all is lost anyways. With good crank sealing, you should be able to generate at least 20 pounds of vacuum, in a perfect world. After an engine wears - who knows what is possible!
Old 09-21-2012, 09:57:01 PM
I did send pictures to and also spoke with a rep from the Marsh Instrument Company (now "Marsh Bellofram"). He told me that at that time they supplied gauges to many different vendors who would use them to make products for many companies. He also told me that this would be a good representation of how these were customized for a vendor's customers such as Maytag. It would not be uncommon for a vendor to supply the name and it may have been applied by Marsh at the time of the making, rather than do a special face printing for a smaller number of gauges. As they (Marsh) were not the direct vendor to Maytag he could not supply any further information.
I do believe that this is a true test tool for Maytag. It may not have anything to do with the testing of these little engines and have some other unknown Maytag purpose. I do find that the rubber stopper is a perfect fit for a 92 air intake hole. However, this does not explain the other stopper which is too big to fit a 92 intake. Who knows? I also examined the gauge very closely and I do not believe that it has ever been opened up by any individual. Everything looks factory.
Old 09-23-2012, 12:46:28 AM
bigGURN's Avatar
Images: 1
well cool! Thanks for the information!
Old 10-07-2012, 01:59:02 AM
On the washer side of things the automatics have a pressure switch to sense water level. And has a hose attached to it. If the hose and such were to leak the pressure switch would not work correctly so this may have been set up to test the pressure switch system for leaks. Or to test the pressure switch itself. The switch only has a 2 or 3 pounds pressure range I believe. Its as good a thought as any and actually makes more sense then a carburetor tester.
Marvin brought up a good point the carb could not be tested from the intake with this, the vent tube in the carb would by-pass the pressure. I didn't have my thinking cap on straight for that thought, I should have seen that, Hats off to ya Marvin. Mark
Maytag Model 82 Carburetor Status Francis Maytag Engine Collectibles 1 04-04-2011 01:31:07 PM
How do I test a condenser on a Maytag 72D Lvolling Maytag Engine Collectibles 7 02-11-2011 12:00:18 PM
Maytag Engine Model 92 Carburetor Help HarryFetter Maytag Engine Collectibles 0 08-26-2010 11:36:29 AM
Maytag Model 92 Carburetor Check Valve Francis Maytag Engine Collectibles 1 02-02-2010 12:50:41 AM
Maytag 72D compression test? KeithW Maytag Engine Collectibles 10 07-12-2005 02:16:31 PM
