Oil Field Engines
Fairbanks Morse ZC oil pumpjack
this thread has 38 replies and has been viewed 7364 times
Old 10-13-2012, 09:40:59 PM
Gold Dredger Guy Gold Dredger Guy is offline
Default Fairbanks Morse ZC oil pumpjack
Found this in a field, f/m 6-7 hp. missing radiator and cracked head,other than that seems to be in good condition, Didnt realize the weight of this thing till we started to slide it onto the trailer, Wife just shook head and said,Yep sure looks "pretty".
ID:	147089   Click image for larger version
ID:	147090   Click image for larger version
ID:	147091   Click image for larger version
The Following 5 Users Say Thank You to Gold Dredger Guy For This Post:
Old 10-14-2012, 07:45:39 AM
Reed Engine's Avatar
Default Re: Fairbanks Morse ZC oil pumpjack
That's a 118 (in a Bell block, might even be a Bell K7?) and the unit looks like a CMI.
Old 10-14-2012, 10:08:48 AM
Right, it does say Bell 16k7 on the side, gonna pull the head today get it welded this upcoming week, got the gaskets and other that I can see are missing ordered, THe mag is a 1XB2C so trying to locate info about it now, Not sure if its hot or not Will check that when I get some compression off it.
Old 10-14-2012, 10:16:29 AM
dkamp dkamp is offline
eMail NOT Working
Cool find!
Yeah, she's not light. Just the ENGINE is svelte, but looking at the counterweight plates on that jackbeam makes me satisfied that your trailer got a workout...
Reed Engine can help you get the right stuff to wake it up again!
Old 10-14-2012, 02:17:28 PM
Mag takes A2437A points, SXY2433 condenser, R2477C coil, G3861 oil seal, H2498, A4910 gaskets. Points gap at .019
Old 10-14-2012, 10:58:52 PM
OTher than the blown chunk missing on the head, found this little surprise,
ID:	147149   Click image for larger version
The Following User Says Thank You to Gold Dredger Guy For This Post:
Old 10-15-2012, 11:02:53 AM
Whoever was going to braze the crack in the head can take care of that too. Just use a flat file to "resurface". You'll be good to go.
Old 10-19-2012, 06:53:09 PM
Noticed on a picture from the net that there was a fork lever on the clutch assy. Can anyone give me some info on this, Is it standard on this engine or did they vary the kinds on it, Right now its just free to spin.
Old 10-21-2012, 09:34:04 AM
Hand lever clutch, they allow tighter clutch adjustments, possibly safer to use. The hand wheel will bolt right on where that bronze collar is now, hand wheels are far more popular.
Just looked better at your pictures, I'd say yours had a ball bearing hand wheel on it maybe? and it's gone. Does the sliding sleeve have a snap ring groove in it?
Old 10-21-2012, 09:58:48 PM
I do have the wheel, with a bearing in it that will fit over the end and it does have a grove in it that, unsure of how that wheel can press inward to lock the clutch and drive the jack. Guess that's to come after it runs, LOL
Old 10-22-2012, 08:24:48 AM
Strong arms.
Old 10-30-2012, 07:22:24 AM
Time to assemble, Torque on the head? I thought maybe the manual I got would share some info but nope, thanks in advance,Rick
Old 12-10-2012, 11:09:30 PM
Beside the governor rod there is another short rod that has a spring on it, What is that for?
Old 12-11-2012, 12:17:48 AM
Used to move the governor spring in or out while the engine is running.
Old 12-11-2012, 09:47:27 AM
vern0n's Avatar
vern0n vern0n is offline
Were you able to get the well also? Nice find! Shouldn't be too much trouble fixing that head. It is a common problem on FM engines.
Old 12-12-2012, 11:17:05 PM
I looked at my book and anything that I have found online, at this rod, Does it hook to anything, I have the bracket that it slides through but the end that is near the gov assy that comes from the engine is just a blunt end, ?
with the butterfly in any position it will not appear to be able to hold or move Seems that it is going to be about 1 inch too long/
Old 12-12-2012, 11:30:57 PM
I told you what it was in about two posts ago. The second part of your last question I do not understand. Are you talking about the gov pull rod? If its too long maybe the arm it attaches too at the gov end is not attached in its correct position. ?
I need a photo to see what your talking about.
Old 12-13-2012, 04:06:34 PM
This is it. Might be missing something.
ID:	152024   Click image for larger version
ID:	152025   Click image for larger version
Old 12-13-2012, 09:09:37 PM
That's exactly how it is supposed to look (other than the rust etc).
It's purpose is to move the governor spring in and out on it's toothed lever. You hold the knurled end with your fingers and manipulate it to get the end of the rod (it's cupped) over the end of the spring. Then you can move the spring right (faster) or left (slower). You can do this while the engine is running, the little rod (whatever it's name is?) is to keep the flywheel from rubbing your hand.
Old 12-13-2012, 10:15:56 PM
Thanks By looking at it ,doesn't look complete, Valuable to have y'all's knowledge on this stuff, keep fingers crossed, Saturday weather permitting, test run.
FM Pumpjack Brickman Antique Gas Engine Discussion 2 04-11-2009 08:14:34 AM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Antique Gas Engine Discussion 4 09-12-2008 11:03:58 AM
PumpJack add on for 3-5 IHC LB? Alltractorman Antique Gas Engine Discussion 8 01-27-2006 10:57:34 AM
What Do I Do With My Pumpjack????? MedicHamilton Antique Gas Engine Discussion 3 03-31-2005 09:48:35 AM
Fairbanks Morse pumpjack for a 1914 Eclipse Eng. Phil Krull Antique Engine Archives 0 03-01-2002 08:51:06 PM
