Wisconsin Engines
Need Flywheel for Wisconsin THD
this thread has 2 replies and has been viewed 1507 times
Old 01-19-2013, 06:19:29 PM
Buckshot7711 Buckshot7711 is offline
Default Need Flywheel for Wisconsin THD
Anyone out there looking to get rid of a flywheel and starter shroud for a Wisconsin THD/TJD? I am looking to convert a THD over to electric start, so flywheel must have ring gear. I will settle for the just the ring gear and shroud if need be, any help would be greatly appreciated. PM me with prices/availablility.... Thanks guys!
Old 01-19-2013, 11:15:20 PM
K-Tron K-Tron is offline
Default Re: Need Flywheel for Wisconsin THD
I have a flywheel for a THD with a ring gear on it.
The flywheel I have is not machined for a flywheel alternator.
I do not have a starter shroud, starter mount, starter or alternator for this setup. Let me know if you are interested. You are not too far away,
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 01-20-2013, 08:27:04 AM
Yeah cool- how much do you want for the flywheel? It will get me started- I really appreciate it. -Larry
Wisconsin TFD flywheel Saukengines Wisconsin Engines 7 12-29-2011 12:40:19 PM
Wisconsin AEH Flywheel removal Skyhawk Greg Wisconsin Engines 30 10-08-2007 03:41:59 PM
Wisconsin S-8D flywheel WilsonsK Magnetos, Ignition Coils and Spark Plugs 0 03-21-2007 02:13:26 PM
Wisconsin TH Flywheel Brian Tindall Generators & Electric Motors General Discussion 4 09-29-2003 09:43:37 PM
Wisconsin Flywheel Mark L Shattuck Antique Engine Archives 0 03-20-2001 07:56:39 PM
