Oil Field Engines
My Reid pictures!
this thread has 9 replies and has been viewed 3533 times
Old 01-29-2013, 08:29:36 PM
Jeff Holbrook Jeff Holbrook is offline
Default My Reid pictures!
Here are some pictures of my Reid. Hope you like them. Sincerely, Jeff
ID:	156449   Click image for larger version
ID:	156450   Click image for larger version
ID:	156451   Click image for larger version
Old 01-29-2013, 08:51:22 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Default Re: My Reid pictures!
Looks like a good engine . Lh newer Script , I have the twin to it # 17804. whats the serial # ?
Skidmore aka engine hoarder
The Following User Says Thank You to Skidmore For This Post:
Old 01-30-2013, 09:42:22 PM
I'll get back with you on the ser# I'm about 2hrs away from it! Later, Jeff
Old 08-25-2013, 11:15:38 PM
Default Re: My Reid pictures at Eau Claire and Edgar, WI.
Here are a couple of pictures of my Reid on it's way to Edgar WI. and one at the Edgar show. Ran well!!
ID:	173243   Click image for larger version
ID:	173244   Click image for larger version
ID:	173245   Click image for larger version
The Following 4 Users Say Thank You to Jeff Holbrook For This Post:
Old 08-26-2013, 01:43:39 PM
Reed Engine's Avatar
Thumbs up Re: My Reid pictures!
Man I like that engine base. Looks like it belongs right out in the field working. Thanks for posting these!
Old 08-26-2013, 06:07:20 PM
Pete Deets Pete Deets is offline
Jeff,
I enjoyed seeing your engine run at Edgar. Did you ever get the other one to start?.....PD
The Following User Says Thank You to Pete Deets For This Post:
Old 08-31-2013, 06:52:11 PM
Wink Re: My Reid pictures!
Hello Pete. Nope I couldn't get enough compression to keep it running. I'll soak it over the winter. Next year!!
---------- Post added at 05:52 PM ---------- Previous post was at 05:49 PM ----------
This is my first try at U tube!!! Check it out??? Thanks, Jeff http://youtu.be/WeE__c7w9_s
The Following 2 Users Say Thank You to Jeff Holbrook For This Post:
Old 03-03-2014, 09:10:19 PM
Default Re: My Reid, Is it left or right?? Watch my video
Can anyone tell me if this is a right or left handed Reid? And how do you tell? I know the cylinder is on the opposite side but from what end do you look from? While you are here, please watch my you-tube video. Thanks, Jeff http://www.youtube.com/watch?v=WeE__c7w9_s
The Following User Says Thank You to Jeff Holbrook For This Post:
Old 03-03-2014, 09:58:49 PM
hitnmis Alex's Avatar
hitnmis Alex hitnmis Alex is offline
Left hand reid, think of it as a driver side car
The Following User Says Thank You to hitnmis Alex For This Post:
Old 03-04-2014, 09:46:57 AM
Alex is right, as you are standing in front of the engine looking at the cylinder it is the side where the clutch would be mounted.
That is one sweet running Reid!
The Following User Says Thank You to Ray Ethridge For This Post:
2008 Nuenen rally pictures - first pictures online - Oostvogels Antique Gas Engine Discussion 32 05-19-2008 02:34:00 PM
Reid detail pictures KeithW Oil Field Engines & Related Equipment 2 10-30-2006 03:13:08 PM
How much $$$ for reid JHFoster Oil Field Engines & Related Equipment 4 09-23-2006 01:02:19 PM
Reid / Prony Brake pictures ListerDiesel Oil Field Engines & Related Equipment 1 07-04-2006 09:47:48 AM
4hp reid DICK BROWN Antique Engine Archives 3 10-28-2003 11:34:27 PM
