Oil Field Engines
Superior found in the wild
this thread has 32 replies and has been viewed 8939 times
Old 08-17-2013, 12:22:44 PM
johnk907 johnk907 is offline
Default Re: Superior found in the wild
Dwayne, Picture number two looks like a winch me out of here to me.
John
Old 02-09-2014, 11:58:11 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
I got the superior moved into the shop on Saturday and had to start wrenching on it right away. I pulled the covers off of the valves and of course dirt dabbers and mice had been in there. I didn't really want to pull the head because it is so heavy so I made a red neck attachment for the shop vac and sucked up all the dabber nest and rat pills. This is a massive engine, the exhaust valve weighs 5 pounds. I hope to have this beast running in time for my gas-up on April 26th.
ID:	187449   Click image for larger version
ID:	187450   Click image for larger version
ID:	187451   Click image for larger version
The Following 4 Users Say Thank You to Dwayne Fuller For This Post:
  #23
Old 02-10-2014, 12:00:19 AM
Pictures of the red neck vacuum attachement
ID:	187453   Click image for larger version
ID:	187454   Click image for larger version
ID:	187455   Click image for larger version
The Following 3 Users Say Thank You to Dwayne Fuller For This Post:
  #24
Old 02-10-2014, 12:05:22 AM
I need to make gaskets for the valve covers as the old copper and asbestos sandwich gasket didn't survive. I have some Armstrong Thermo-Tork TN-9001, will this work for my application?
ID:	187458   Click image for larger version
Old 02-10-2014, 12:51:05 AM
Dwayne,
Pictures are encouraging. I predict you will have it running by April.
John
Old 02-10-2014, 10:11:35 AM
Ray Ethridge's Avatar
Great looking project Dwayne, I am looking forward to seeing it run in April. That gasket material is a latent cure material, meaning it will cure with heat after it is installed. It is rated for 750 F and 2000 PSI tensile, so you will not even come close to approaching those conditions with it just idling along. There is such a small amount of the gasket that would be exposed to the exhaust that I think the worst that could happen would be a small amount of char that would be formed right on the inside rim. That char will protect the rest of the gasket. You will probably never have to worry about that gasket again.
The Following User Says Thank You to Ray Ethridge For This Post:
  #27
Old 02-10-2014, 11:34:17 AM
Thanks Ray. I may be missing something in the fuel mixer. In the thread about the two superiors in one photo you can see a small rod sticking up through the top of the big casting on the mixer. Mine has hole there that is not threaded. I will try to take it apart and get photos today.
The Following User Says Thank You to Dwayne Fuller For This Post:
  #28
Old 02-12-2014, 10:39:08 AM
The project is coming right along. Both valves cleaned up nice and have been re-installed. Will work on the side shaft and governor stuff today. I need to know what is missing from the mixer. It seems to be some sort of plunger or float. Can I plug the hole on top and just run this with a diamond valve.
ID:	187717   Click image for larger version
Old 02-12-2014, 11:05:14 AM
Kirk Taylor Kirk Taylor is online now
Dwayne,
There is supposed to be a leather-faced valve that seats on the two narrow faces at the bottom of the hole. Its purpose is to shut off the gas when the engine isn't intaking and to compensate or adjust the mixture as the throttle position changes.
You can probably just run it on the gas cock if you're not powering anything.
There's a 25hp industrial Superior close to me that I can grab a photo of if you want. You would need only to adjust the size to fit your engine.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
  #30
Old 02-12-2014, 06:53:22 PM
Kirk, Thanks for the info. I talked to a guy this morning that thinks he has a few extra mixers. He is going to check for one when it warms up. We had an inch of ice here this morning and they are saying 75 degrees by Sunday.
Old 02-13-2014, 10:48:38 PM
Done a little more wrenching on the Superior today. I had to take the rear bearing off the side shaft to clean it so I made some timing marks. After a good cleaning I found the original timing marks and another set some else had put on there. The factory timing marks are out by one tooth. Whoever worked on the engine last left the set screw out of the bearing stop on the side shaft. It had slid up about six inches from the bearing so it was doing no good, I found an inspectors mark under the bottom part of the bearing support. Hope it shows up in the pics.
ID:	187881   Click image for larger version
ID:	187882   Click image for larger version
ID:	187883   Click image for larger version
The Following 2 Users Say Thank You to Dwayne Fuller For This Post:
  #32
Old 02-13-2014, 10:55:16 PM
The gov. shaft was stuck but I got it free with a little oil and tapping back and forth. There seems to be a lot of end play in the shaft and I see no way to take it out. With the gov. on the engine gravity is holding it down and making the gears meash but with the end play you can pull the shaft up about 1/4 inch. I did not take the gov. completely apart so I may be missing something here. Anyone know how this is supposed to work?
ID:	187885   Click image for larger version
ID:	187886   Click image for larger version
Old 04-22-2014, 11:17:04 PM
Nolan Fuller Nolan Fuller is offline
Got the Superior cranked and running ready for the 11th annual gas-up, come watch it run! Side by side with a 25 horse Fairbanks NB and a 35 horse Krueger Atlas in the background.
Still some maintenance to do on it after a slight water explosion, shortly after this video was taken.
The Following 2 Users Say Thank You to Nolan Fuller For This Post:
Found in the Wild Todd Hodges Antique Gas Engine Discussion 0 12-16-2012 09:33:19 PM
It's been a while since I found one in the wild vern0n Antique Gas Engine Discussion 5 04-18-2010 08:34:07 PM
Hercules 8XK found in the wild! Greg-N-CA Antique Gas Engine Discussion 16 03-16-2010 01:00:28 AM
Another one found in the wild... tim l kesler Antique Gas Engine Discussion 3 10-04-2009 10:05:03 PM
Look what I found in the wild RustyironinMO Antique Gas Engine Discussion 6 02-19-2006 12:27:14 AM
