Steam Engines
Trumbull County Show May 30, 31 & June 1, 2013
this thread has 18 replies and has been viewed 3843 times
Old 05-19-2013, 10:19:43 AM
Beth V's Avatar
Beth V Beth V is offline
Default Trumbull County Show May 30, 31 & June 1, 2013
The 6th Annual Trumbull County Steam Engine and Old Tractor Reunion is May 30th through June 1st.
Steam Traction Engines
Model Steam Engines
Antique Gas Tractors
Antique Gas Engines
Saw Mill
Baker Fans
Power Eater (Dynamo)
Rock Crusher
Tractor Pulls
Tractor Games
Amish Cooking
Homemade Ice Cream
Spark Show Friday Night
An Much More
The show grounds are located at:
9766 Bundysburg Rd.
Middlefield, OH 44231
For further information, post questions here or call:
Jonas Stutzman
440-632-0052
The Following 9 Users Say Thank You to Beth V For This Post:
Old 05-20-2013, 06:38:27 AM
Butch KG1775's Avatar
Butch KG1775 Butch KG1775 is offline
Default Re: Trumbull County Show May 30, 31 & June 1, 2013
The Bieseckers will be there.
The Following 2 Users Say Thank You to Butch KG1775 For This Post:
Old 05-20-2013, 12:22:02 PM
Dan Donaldson's Avatar
Dan Donaldson Dan Donaldson is offline
Will the Bieseckers be bringing and toys (steam engines) with them?
Old 05-20-2013, 08:45:55 PM
The engines are at Jonas now im bringing the advance trama truck.Butch
Old 05-20-2013, 08:51:30 PM
Beth V's Avatar
This should be good................
Old 05-20-2013, 09:00:13 PM
Thank goodness! It has gotten me out of a jam more than once. Who knew an Advance could run with the cylinder head removed.
The Following 2 Users Say Thank You to Dan Donaldson For This Post:
Old 05-20-2013, 10:16:58 PM
Thomas Diehl Thomas Diehl is offline
Butch : Knowing that your "Trama truck and tools" will be there , I think I will pack lite on my tools!!!!(Tool rentals available???)---------------------TWD
Old 05-21-2013, 06:41:43 AM
Does this mean there will be two Russells on the grounds
Old 05-21-2013, 07:05:17 AM
Butch:If I get everything ready by then. Did not get the gear guards done ,so might need to stay out of the gravel !!!!---------------------------TWD
The Following 2 Users Say Thank You to Thomas Diehl For This Post:
Old 05-24-2013, 10:23:53 PM
Beth V's Avatar
Any photos of the engines as they get ready to play?
The Following User Says Thank You to Beth V For This Post:
Who is taking a model to Trumbull County in 2012 Dale Miner Steam Stationary Engines, Traction Engines, Steam Boats 17 02-13-2012 05:35:57 PM
Third Annual Trumbull County Ohio Show greysteam24hp Steam Stationary Engines, Traction Engines, Steam Boats 49 06-16-2010 07:58:54 PM
Trumbull County Ohio 2010 show photos Emma Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 06-05-2010 06:41:19 PM
Trumbull County Ohio 2010 show photos Emma Antique Gas Engine Discussion 0 06-05-2010 12:46:24 PM
2nd Annual Trumbull County Show greysteam24hp Steam Stationary Engines, Traction Engines, Steam Boats 26 05-23-2010 09:09:01 AM
