Maytag Model 92 serial number location
this thread has 7 replies and has been viewed 4793 times
Old 10-05-2013, 01:47:20 AM
shattercane shattercane is offline
Default Maytag Model 92 serial number location
I have a Model 92 Maytag (inherited from the family) that is pretty rough but is loose. I am trying to figure out what year it is but am not finding a serial number anywhere on or near the fly wheel. Can some one tell me where I need to clean additional grease and dirt from? It appears that both valves are operational but while I have the head off I want to re-ring it, how does one go about getting to the crank to get the piston out? Sorry for the rookie questions,
Thanks in advance for any suggestions and support.
Travis
Old 10-05-2013, 09:29:20 AM
Mark Shulaw Mark Shulaw is offline
Default Re: Maytag Model 92 serial number location
Are you sure you have a Maytag? The way you ask the questions makes me think you may have something else like a Briggs. Post a picture. If it is a Maytag the serial number will be on the rim of the flywheel above the points inspection cover. Mark
The Following User Says Thank You to Mark Shulaw For This Post:
Old 10-05-2013, 10:54:39 AM
Thanks for the reply Mark...I guess I was under the impression that it was a maytag simply based on the similarities to a 92, here are a few pictures.
Thanks again,
Travis
The Following User Says Thank You to shattercane For This Post:
Old 10-05-2013, 10:57:04 AM
I forgot to mention that I have the head and outer pulley's removed, but I'm guessing you have that figured out already.
Old 10-05-2013, 12:21:11 PM
Chad Johnson Chad Johnson is offline
that's a Johnson Iron Horse
serial number was on a tag on the air shroud
The Following 2 Users Say Thank You to Chad Johnson For This Post:
Old 10-05-2013, 12:25:12 PM
I am not that familiar with that one, does anyone have a positive ID? I am thinking Iron Horse??
Old 10-05-2013, 02:39:49 PM
I guess that shouldn't be a shocker to me as I didn't see Maytag anywhere on the engine. Is the hunt for parts going to be any more difficult for this model and is it worth any more or less than a Maytag?
Thanks for the assistance fellas,
Travis
Old 10-05-2013, 09:05:38 PM
Thiel's Avatar
Thiel Thiel is offline
yeah, Iron Horse, probably a X-3... or X-2... series type.
Parts may be not as plenty full as for the Maytags, but looking at the right places (here, Ebay, local shows and swap meets) should be able to find what you need to get them going.
Value... always wide open for speculation, what I've seen that Maytags, although nearly on every corner, fetch a higher price than the Iron Horse. But after you go through the resurrection process you will treasure them a little higher.
The Following User Says Thank You to Thiel For This Post:
Lister SR-2 Serial Number Location Joseph Vintage Diesel and Oil Engines 12 08-06-2014 04:40:56 AM
Gilson serial number location BobRR Antique Gas Engine Discussion 10 11-15-2008 03:29:53 PM
Novo Serial number location jmsolomonson Antique Gas Engine Discussion 4 04-08-2008 11:01:30 PM
Stickney Serial Number Location Danny G Antique Gas Engine Discussion 1 01-12-2007 02:40:36 PM
galloway serial number location Tim Rostar Antique Gas Engine Discussion 1 07-23-2006 06:37:06 PM
