Oil Field Engines
Oilwell Supply 20 HP Single Valve Simplex
this thread has 32 replies and has been viewed 5755 times
Old 10-22-2013, 04:01:33 PM
jeeperforlife jeeperforlife is offline
Default Re: Oilwell Supply 20 HP Single Valve Simplex
Not that im advocating one way or the other, (as I definitely wouldnt argue with John), but if you dont put the fuel to it until you stop admitting compressed air, i dont see how you could overpressure the cylinder.
Old 10-23-2013, 10:24:52 PM
Thanks Ray, let me know when you PERFECT the design - I need one for the same multiple engine use that you describe. Bill
[QUOTE=Ray Ethridge;968296]Thanks Bill. The exhaust pipe came from one of the earlier caretakers of this engine.
I hesitated to show the details of this starter because it is DANGEROUS.
Old 10-25-2013, 01:53:14 PM
Ray Ethridge's Avatar
I took a few pictures inside the bore after I opened it up. The cylinder is probably the best looking cylinder I have ever seen in an oilfield engine. The first picture is the cylinder bore. The second shows the exhaust ports for the ported exhaust. The exhaust ports are at about the 10 oclock position, I had the camera tilted to see the best view of the ports. The next picture shows the valve as viewed from the cylinder. It is open. And the last picture shows the area where the head gasket was leaking. There is a slight problem with the casting of the head, but I think the real problem was the gasket itself. It appeared to have been broken and a piece missing in the area of the leak. Maybe someone tried to reuse the head gasket and did not notice that it was broken?
ID:	177989   Click image for larger version
Name:	exhaust ports.jpg
ID:	177990   Click image for larger version
Name:	valve view from cylinder.jpg
ID:	177991   Click image for larger version
The Following User Says Thank You to Ray Ethridge For This Post:
  #24
Old 10-25-2013, 01:59:04 PM
A new gasket was cut and fitted on the engine. The engine runs MUCH better now. I did find out that the check valve will have to be serviced very frequently. The engine ran fine the first day, but when I tried to start it the second day the check did not seem to be working. I opened it up and found that the soot from the day before had caused the valve to hang. After thorough cleaning the engine ran just fine. The hit or miss governor is now working, the reason the engine only hits once or twice then coasts a while is because of the governor. The first picture shows the gasket as cut, and the second picture shows it on the head just prior to putting the head back on. I spray painted the edges of the gasket with black paint so that the greenish color would not show on the engine.
ID:	177993   Click image for larger version
Name:	gasket fits pretty good.jpg
Old 10-25-2013, 03:05:09 PM
Here is the engine running after the head gasket repair. I am reversing the direction of the engine several times in this video. This is one of the few 4 stroke engines that can do this. This is also a hit or miss engine. The governor is working very well here, that is the reason the engine only fires a time or two and then coasts.
http://youtu.be/8V35IYgIYvk
The Following 7 Users Say Thank You to Ray Ethridge For This Post:
  #26
Old 10-25-2013, 09:18:27 PM
Steve Webre Steve Webre is offline
Very nice Ray!! Good job.
The Following User Says Thank You to Steve Webre For This Post:
  #27
Old 10-25-2013, 10:06:20 PM
Thanks Steve, it was a fun engine to work on, at least after I got the starter motor built. I whipped me down big time before I got that built though. Today I found that the main bearings and the rod bearing were not really getting oil. I cleaned out the oil passages and it is turning a lot easier now. Before I could just barely move it by hand.
Old 10-26-2013, 10:29:53 AM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Ray, That is a great running engine. Thanks for the video. My S.M. Jones will run either direction if I ever get that basket case put back together. Your Simplex would sure look good at my gas up in April. I think I will feature oil field engines, maybe we could get Shelby to drag one over.
The Following User Says Thank You to Dwayne Fuller For This Post:
  #29
Old 10-26-2013, 11:57:08 AM
Thanks Dwayne. I would love to have it at your show, but I need to sell some of my engines. I have 10 of the big ones and they have just been sitting there for several years. I am going to put several up for sale to try to get them to people that could use them more. It hurts, but it also hurts to see them just sitting there waiting for my attention. I will definitely have some kind of oilfield engine at your place in April. If I still have this one I will bring it for sure though! Shelby definitely has some great ones to show. There are a few others around down here that would make for a really interesting show.
Old 10-27-2013, 09:09:27 AM
Allan Wright Allan Wright is offline
Now I know where to get head gaskets made. That one looks great.
What kind of gasket material is that and how thick? Garlock?
See ya later
The Following User Says Thank You to Allan Wright For This Post:
  #31
Old 10-27-2013, 10:47:35 AM
Jack Innes Jack Innes is offline
Allan,
The Garlock material will work fine but if you need a copper sandwich gasket you might contact "Gaskets to Go", a sponsor of this site. I had the one pictured made by them & the service was good & the price even better. $49 for the gasket & $35 for the ring. Done & in the mail within 2 weeks. ( The bore of the gasket is 13 1/2" - OD about 20")
http://www.smokstak.com/forum/attach...7&d=1375713578
The Following User Says Thank You to Jack Innes For This Post:
  #32
Old 10-27-2013, 11:35:18 AM
Hi Allen, the gasket material is 1/16" NA1001 made by Teadit. It looks like the specs are similar to the Blue Guard series Garlok material. Google NA1001 to see the specs of the material. It is good for continuous use to 460 F and 750 PSI. No way is this gasket ever going to see those kinds of temps or pressures. The way this engine is built the gasket area is shielded from any combustion because the head sticks down inside the chamber a bit. And combustion gases would have to go down inside some pretty small clearance holes to even get to the gasket.
I actually made up an Autocad drawing of the gasket and submitted the DXF file to a local gasket company (eaglegasket.com) for a quote. I had visited them previously and saw their operation, plus they gave me enough drop offs to try the material. Their quote was only $16.50 apiece but it was going to take 4 days, so I made my own on my rotary table and milling machine. I think from now on I will start earlier with the DXF drawing and just get them made, it would save a lot of work.
Old 10-31-2013, 10:58:12 PM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
jeeperforlife is correct about not admitting gas till the compressed air is shut off. You get the engine rolling at a good speed with compressed air only, then after turning off starting air you admit fuel , and hopefully off she goes. If not shut off gas for a few revolutions and repeat. We start a few hot tube engines at Coolspring in this manner. And a friend starts his 25 Simplex single valve in this manner.
Oilwell Supply Power Skidmore Oil Field Engines & Related Equipment 4 07-08-2012 12:39:52 PM
Oilwell Supply halfbreed - please help identify Trd Harper Oil Field Engines & Related Equipment 5 03-17-2012 08:23:43 PM
10 Hp oil Well supply single valve Chris Austin Oil Field Engines & Related Equipment 2 02-16-2009 04:32:13 PM
Single valve Simplex Rich Hudak Oil Field Engines & Related Equipment 1 08-08-2008 11:46:53 PM
Single Valve Simplex Question Jerry Toews Oil Field Engines & Related Equipment 2 07-04-2007 05:43:21 PM
