Oil Field Engines
Oilwell Supply 20 HP Single Valve Simplex
this thread has 32 replies and has been viewed 5663 times
Old 10-27-2013, 10:47:35 AM
Jack Innes Jack Innes is offline
Default Re: Oilwell Supply 20 HP Single Valve Simplex
Allan,
The Garlock material will work fine but if you need a copper sandwich gasket you might contact "Gaskets to Go", a sponsor of this site. I had the one pictured made by them & the service was good & the price even better. $49 for the gasket & $35 for the ring. Done & in the mail within 2 weeks. ( The bore of the gasket is 13 1/2" - OD about 20")
http://www.smokstak.com/forum/attach...7&d=1375713578
The Following User Says Thank You to Jack Innes For This Post:
Old 10-27-2013, 11:35:18 AM
Originally Posted by Allan Wright View Post
Now I know where to get head gaskets made. That one looks great.
What kind of gasket material is that and how thick? Garlock?
Hi Allen, the gasket material is 1/16" NA1001 made by Teadit. It looks like the specs are similar to the Blue Guard series Garlok material. Google NA1001 to see the specs of the material. It is good for continuous use to 460 F and 750 PSI. No way is this gasket ever going to see those kinds of temps or pressures. The way this engine is built the gasket area is shielded from any combustion because the head sticks down inside the chamber a bit. And combustion gases would have to go down inside some pretty small clearance holes to even get to the gasket.
I actually made up an Autocad drawing of the gasket and submitted the DXF file to a local gasket company (eaglegasket.com) for a quote. I had visited them previously and saw their operation, plus they gave me enough drop offs to try the material. Their quote was only $16.50 apiece but it was going to take 4 days, so I made my own on my rotary table and milling machine. I think from now on I will start earlier with the DXF drawing and just get them made, it would save a lot of work.
Old 10-31-2013, 10:58:12 PM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
jeeperforlife is correct about not admitting gas till the compressed air is shut off. You get the engine rolling at a good speed with compressed air only, then after turning off starting air you admit fuel , and hopefully off she goes. If not shut off gas for a few revolutions and repeat. We start a few hot tube engines at Coolspring in this manner. And a friend starts his 25 Simplex single valve in this manner.
Oilwell Supply Power Skidmore Oil Field Engines & Related Equipment 4 07-08-2012 12:39:52 PM
Oilwell Supply halfbreed - please help identify Trd Harper Oil Field Engines & Related Equipment 5 03-17-2012 08:23:43 PM
10 Hp oil Well supply single valve Chris Austin Oil Field Engines & Related Equipment 2 02-16-2009 04:32:13 PM
Single valve Simplex Rich Hudak Oil Field Engines & Related Equipment 1 08-08-2008 11:46:53 PM
Single Valve Simplex Question Jerry Toews Oil Field Engines & Related Equipment 2 07-04-2007 05:43:21 PM
