Oil Field Engines
Building a FM 118 crankshaft?
this thread has 51 replies and has been viewed 6745 times
Old 11-06-2013, 09:07:21 AM
Reed Engine's Avatar
Default Re: Building a FM 118 crankshaft?
May be a little off topic but right on center. I'll start another thread about that subject in smoke and flames but Elden you couldn't be more right.
Old 11-06-2013, 07:58:32 PM
Finally talked to my welder friend and he have me some info on pre and post heating. He said preheat wasn't all that important but some would be good to get the moisture out of everything. Also need to get the core up to temp so the preheat needs to be slow. After welding to keep hydrogen from forming and cracking the welds he said to hold it in the furnace for a while then put it in the sand to cool down.
---------- Post added at 05:53 PM ---------- Previous post was at 05:50 PM ----------
I did a little home work on hydrogen and found it dissipates 1" in 48 hrs at room temp and 1" in 1hr at 450. So I can see the value in keeping the heat on it for a while after the welding.
---------- Post added at 05:56 PM ---------- Previous post was at 05:53 PM ----------
And yes, I don't fully understand all this but I'm learning.
---------- Post added at 05:58 PM ---------- Previous post was at 05:56 PM ----------
Here's the read on hydrogen cracking.
http://content.lincolnelectric.com/p...ldcracking.pdf
Old 11-06-2013, 08:19:22 PM
JIMnWV's Avatar
JIMnWV JIMnWV is offline
eMail NOT Working
The crank in my O'l Harley is 5 seperate pieces, 3 seperate shafts, and 2 balance wheels with taper / keyed fit held together with a nut torgued to specs. Very interesting what you are trying to do here Reed, looking forward to seeing the detail of your project.
Jim
Old 11-06-2013, 08:56:00 PM
Thought about doing mine with tapers as well. I'm sticking with what I've decided.
Old 11-06-2013, 11:45:10 PM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
Here is a link to a post of a crank I made a few years ago.
http://www.smokstak.com/forum/showthread.php?t=57033
The Following 2 Users Say Thank You to Chris Austin For This Post:
  #46
Old 11-07-2013, 09:28:07 AM
Excellent! If my approach doesn't work I'm going to try one using that same method. I won't have to leave those tabs on the end to do the throw though as I have an offset fixture.
---------- Post added at 07:28 AM ---------- Previous post was at 07:19 AM ----------
The tabs were a good idea though.
Old 11-07-2013, 11:56:36 AM
Just got a picture of the journals
  #48
Old 11-07-2013, 03:57:21 PM
How about a picture of your offset fixture? For the Idea closet.
Old 11-07-2013, 05:19:50 PM
---------- Post added at 03:14 PM ---------- Previous post was at 03:12 PM ----------
---------- Post added at 03:19 PM ---------- Previous post was at 03:14 PM ----------
The throw goes in between the shafting (pinch fit), that way the crank isn't flexed when chucked and centered.
  #50
Old 02-17-2014, 05:58:12 PM
Thob Thob is offline
Well??? The holidays are over. Did it work? Pictures? Curious minds want to know!
Old 02-17-2014, 07:53:00 PM
Back burnered for now. Sometimes work gets in the way of fun.
  #52
Old 02-17-2014, 09:38:39 PM
I understand - I also have a day job, which I need for gas, groceries, and hobbies.
Building a shop, what would you do? Craig M. Strader Sr. Antique Gas Engine Discussion 111 10-22-2012 11:05:22 AM
American boy ad on building Farmer John Antique Gas Engine Discussion 10 08-07-2011 10:28:27 PM
Building A Governor n47ie5 Steam Stationary Engines, Traction Engines 14 10-11-2010 12:17:50 AM
Building a cart BBishop Antique Gas Engine Discussion 10 10-31-2006 06:06:14 PM
