Oil Field Engines
We Want to See Your Oilfield Engines
this thread has 39 replies and has been viewed 9148 times
Old 12-15-2013, 08:37:47 PM
Jonah Close Jonah Close is offline
Default We Want to See Your Oilfield Engines
Im posting this thread to compile photos of oilfield engines of all kinds for others to enjoy. Half-breeds, four cycle, Reid, Bessemer, and all others are all welcome!
Include a brief history and maybe some tips along the way if you'd like.
Old 12-15-2013, 08:45:07 PM
KevinJ KevinJ is offline
Default Re: I wanna see your oilfield engines!
Not mine exactly but I have ran it for the local club. Does anyone know about operating and adjusting these for propane?
ID:	182145   Click image for larger version
ID:	182146   Click image for larger version
1950 Farmall M, 1962 Farmall 560D, Kubota GL3940HSTC, Kubota B7500, Kubota BX1860, many implements, etc.
The Following User Says Thank You to KevinJ For This Post:
Old 12-16-2013, 12:24:26 AM
Default Re: We Want to See Your Oilfield Engines
Anybody?
Old 12-16-2013, 06:55:42 PM
tyrion's Avatar
tyrion tyrion is offline
Images: 42
This is how my Franklin used to be plumbed up, it ran well with about 4" feeding her. I have changed the air intake around now I use a 2" plug valve to control intake air and this smoothed it out a lot. I also found that if I used some rope packing in the pump chamber gland box to help seal it up that really helped starting and running. http://youtu.be/KW_Bl_IX2TA
The Following User Says Thank You to tyrion For This Post:
Old 12-16-2013, 08:09:50 PM
What are you calling a pump chamber gland box????
I thought about the intake, that flap disc is not very good a low loads.
I have already reduced the gas valve and the mag is weak, that is getting rebuilt this winter.
I know it will run better with a good mag.
I hope to give this job to someone else next year.
Old 12-16-2013, 08:42:23 PM
Bob Burlison Bob Burlison is offline
Don't know how to get pics on here. send me your email address and I'll mail you pics. of my 1907 left hand REID 15 HP. At Sistersville last summer. Thanks, Bob
The Following User Says Thank You to Bob Burlison For This Post:
Old 12-16-2013, 09:56:20 PM
Its Stuckpistons1@gmail.com Ill see if I can post them for you.
Old 12-17-2013, 12:32:04 AM
JTrent JTrent is offline
Here is my 10 and 15hp Spang Oilfield Engines on display in Decatur, AL
The Following 4 Users Say Thank You to JTrent For This Post:
Old 12-18-2013, 08:02:16 PM
tyrion's Avatar
Images: 42
[QUOTE=KevinJ;989406]What are you calling a pump chamber gland box????
In your pictures, the one that has the cover that say's Franklin Valveless behind that cover you will find the crosshead and the round rod that goes to the piston. The round rod goes through a gland that has two bolts that hold it in place. take those two nuts off and slide the gland back towards the crosshead, now you can look in that round cavity that the rod is in and there is, at least on my engine two seals. The seals on my engine are 3 piece and have a spring around them that keep them snug around the rod. On my engine there was about a 1/4" of extra space front to back almost room enough for a third seal, also the round cavity the seals are in (gland box) was worn larger than the OD of the seals. I used 3/8" graphite rope packing and made a third seal. Now when I put the glad back on and tighten it, this three seal arrangement snugs down on the rod and seals the pump chamber much better.
The Following 2 Users Say Thank You to tyrion For This Post:
Old 12-18-2013, 08:37:17 PM
Mark Mohney's Avatar
Mark Mohney Mark Mohney is offline
Images: 84
Here's a picture of my 5hp Bessemer
The Following 7 Users Say Thank You to Mark Mohney For This Post:
Oilfield engines in OZ LizRon Smokstak Down Under 0 05-20-2013 04:31:15 AM
Oilfield Engines on the I-10 highway... JIMnWV Oil Field Engines & Related Equipment 11 04-14-2012 12:02:09 PM
Convertable Oilfield Engines Doug Waggonner Oil Field Engines & Related Equipment 7 12-20-2010 09:09:33 PM
What is your opinion on Oilfield Engines zach Antique Engine Archives 11 05-30-2002 06:59:43 AM
Oilfield Powers and Engines Tim Knierim Antique Engine Archives 0 09-12-1999 10:48:57 AM
