Oil Field Engines
We Want to See Your Oilfield Engines
this thread has 39 replies and has been viewed 9227 times
Old 12-24-2013, 05:38:42 PM
Greg Mosley Greg Mosley is offline
Photo Re: We Want to See Your Oilfield Engines
Lets try it again
The Following 3 Users Say Thank You to Greg Mosley For This Post:
Old 12-24-2013, 07:48:21 PM
Clayton Clayton is offline
Default Re: We Want to See Your Oilfield Engines
ID:	182918 15hp oil city half breed
The Following 3 Users Say Thank You to Clayton For This Post:
  #23
Old 12-24-2013, 09:50:25 PM
karst9 karst9 is offline
Originally Posted by Leonard Fausset View Post
Here is one i recovered from the oil field in russell, kansas. It had been off the well for about 25 years and sitting in the pasture, piston stuck hard.
I've been in the oilfield for over 35 years around the Russell area and never seen this engine and talked to a buddy of mine and he never seen it, and we was wondering what oil company had this and what area from Russell this engine was at. Theres still a few engines like a superior and a big continental engine made by fairbanks morse that are still in old engine sheds around the area. We would like to know the history of this engine. Thanks Kirk
Old 12-25-2013, 12:40:56 PM
John C. Neagley John C. Neagley is offline
Here's some of my S.M. Jones engines. 1st is a 12hp, 2nd is a 10hp, 3rd is a 20hp, and last is a 16hp.
ID:	182975   Click image for larger version
ID:	182976   Click image for larger version
Name:	2013-11-25 05.04.02.jpg
ID:	182977   Click image for larger version
The Following 10 Users Say Thank You to John C. Neagley For This Post:
  #25
Old 12-25-2013, 07:06:40 PM
Rod Fielder Rod Fielder is offline
they come and they go.
Name:	Copy of 101_8540_opt.jpg
ID:	183006   Click image for larger version
Name:	EBAY 1 560_opt.jpg
The Following 11 Users Say Thank You to Rod Fielder For This Post:
  #26
Old 12-26-2013, 11:37:10 AM
Jack Innes Jack Innes is online now
Here are some in progress pictures of my Clark 40 hp taken early this year. It has since had all plumbing made & installed, new 10.00X20 tires & new head gasket. It is now running on propane & is inside its building. I still need to address a timing issue - it fires too early. Work will resume In the spring.
ID:	183058   Click image for larger version
ID:	183059   Click image for larger version
The Following 3 Users Say Thank You to Jack Innes For This Post:
  #27
Old 12-28-2013, 05:46:52 PM
tyrion's Avatar
tyrion tyrion is offline
Images: 42
My 25 hp Franklin OCGL, it came off a oil lease in Ohio in the early 1970s. Went to East central Illinois, was overhauled and was shown in that area till I got it a couple of years ago.
ID:	183224   Click image for larger version
ID:	183225   Click image for larger version
Old 12-29-2013, 07:35:17 PM
Tim B's Avatar
Tim B Tim B is offline
Well, at least 1 of these runs so far. Still looking for mag bracket for the Kootz and lots of parts for the Superior (piston,cylinder and crankshaft) well, maybe another engine.
ID:	183365   Click image for larger version
ID:	183366   Click image for larger version
Old 01-01-2014, 10:39:16 AM
Skidmore's Avatar
Skidmore Skidmore is offline
Name:	Engine & wheels show 003.jpg
ID:	183595 1898 15hp Reid #545. All serial #s match with original cast Iron tag. No weights on the flywheels or plates on the cylinder. Check out the exhaust pipe on the side of the cylinder. Maybe a one of a kind?
Name:	April 27 2011 001.jpg
ID:	183596   Click image for larger version
Name:	Jan 1 2012 020.jpg
Skidmore aka engine hoarder
The Following 4 Users Say Thank You to Skidmore For This Post:
  #30
Old 01-01-2014, 02:05:35 PM
Ray Ethridge's Avatar
I have already posted a thread on the 20 HP Single Valve Simplex but this picture was taken just a few minutes ago as the engine was running. This was the first engine I have run in 2014.
Name:	1-1-14 simplex running 1 (2).JPG
The Following 2 Users Say Thank You to Ray Ethridge For This Post:
  #31
Old 01-05-2014, 02:40:55 PM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
It's a 346. Souped up. Modified just a little.
Old 01-05-2014, 08:35:56 PM
Phil P Phil P is offline
Hi
Here are pictures of the SM Jones Sucker rod and a Bessemer mill engine.
Phil P
The Following User Says Thank You to Phil P For This Post:
  #33
Old 01-05-2014, 09:17:26 PM
like the "headless" steam engine you have there, it is a hog trough of some type isn't it?
The Following User Says Thank You to Ray Ethridge For This Post:
  #34
Old 01-15-2014, 12:21:51 PM
Luke Wagner Luke Wagner is offline
My 25hp Reid restored from inside out.
Old 01-15-2014, 02:13:01 PM
hitnmis Alex's Avatar
hitnmis Alex hitnmis Alex is offline
Awesome Reid Luke!! may I ask what the paint color is, any paint codes I would appreciate. Thanks!!!
Old 01-16-2014, 09:09:01 AM
typak typak is offline
Here's my Lytle halfbreed,yes it's a long way from pa, have a couple of Bessemers and a McEwen also. Temp around 40c here in Oz today.
Kim S
The Following User Says Thank You to typak For This Post:
  #37
Old 01-16-2014, 01:19:41 PM
johnk907 johnk907 is offline
Ray, did it start OK!
The Following User Says Thank You to johnk907 For This Post:
  #38
Old 01-16-2014, 10:22:21 PM
Yes John it starts great. I have figured out what pressure to set the hot tube at and where to set the needle valve for the fuel. It does not need the starter motor anymore, it is easy to hand crank. I don't know the "official" way to start it, but I tried starting it the way you would a two stroke and it works. I crank it in the forward direction until it bounces off compression, then crank it in reverse. It almost always fires when it hits compression again and takes right off. I sure would like to see someone else start theirs though to see if I am on the right path. I hope to show it a bunch on the Texas-Oklahoma-Louisiana-Arkanas circuit this summer.
Old 01-17-2014, 12:32:31 PM
Alix it Dupont paint 45827A cost code, general motors, code 79, Dark Carmine, i think that is as close as you can get. Thanks Luke
The Following User Says Thank You to Luke Wagner For This Post:
  #40
Old 04-20-2014, 11:46:01 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Here is a photo of my Oil City/South Penn.
The Following 2 Users Say Thank You to Jonah Close For This Post:
Oilfield engines in OZ LizRon Smokstak Down Under 0 05-20-2013 04:31:15 AM
Oilfield Engines on the I-10 highway... JIMnWV Oil Field Engines & Related Equipment 11 04-14-2012 12:02:09 PM
Convertable Oilfield Engines Doug Waggonner Oil Field Engines & Related Equipment 7 12-20-2010 09:09:33 PM
What is your opinion on Oilfield Engines zach Antique Engine Archives 11 05-30-2002 06:59:43 AM
Oilfield Powers and Engines Tim Knierim Antique Engine Archives 0 09-12-1999 10:48:57 AM
