2x hr Injector Ruston Hornsby 13 hp
this thread has 31 replies and has been viewed 4514 times
Old 03-18-2015, 07:28:42 AM
Brian.P's Avatar
Brian.P Brian.P is offline
Default Re: 2x hr injector ruston hornsby 13 hp
My parts book shows a spring .I remember when I cleaned it all up and put every thing back that is was lose in the case and thought to my self something is missing
my parts book is good for numbers but the cut away isn't greatest for showing the parts how they go in order but at least I know if 1 is missing
Old 03-18-2015, 08:35:29 AM
rustongreen rustongreen is offline
I thot that you had a 2xhr? That parts book would be awesome if you had a 7 to 10 xhr. I'm thinking that your 2 and the 3's should be close for parts just that mine is a little bigger. Your book shows that there is an adapter that the injector line gets screwed onto before the filter. Mine is the line just threads on the filter body and no spring.
Old 03-18-2015, 01:39:12 PM
Brian.P's Avatar
I took a picture of the wrong page but it still shows a spring
it seems these engine have a sleeve if I did need one is there any in Canada
Old 03-18-2015, 08:44:44 PM
That's different, mine shows no spring and it's not loose either. My book shows none of that unless there is a difference with the Mark C and CR parts book compared to a 2 to 3 xhr book.
Old 03-18-2015, 08:59:30 PM
Brian.P's Avatar
i'm not sure what year the parts book is this other book I have is a 1954 it doesn't show a spring
ID:	221252   Click image for larger version
ID:	221253   Click image for larger version
Old 03-18-2015, 09:12:11 PM
There! That's what my book shows. The manual shows that plus the parts book too.
Old 03-18-2015, 09:13:17 PM
Brian.P's Avatar
what year is your engine there must have been a change over at one point
Old 03-18-2015, 09:17:45 PM
That L8023 number that is shown by the breakdown is the same in my book.
One engine Ray had said was sold to Mumford Medland July 21 1936 and my other is a '37
Old 03-18-2015, 09:30:33 PM
Brian.P's Avatar
looks like they started out without a spring then at some point added one and in the 54 book there is none
Old 03-18-2015, 11:13:28 PM
Learn something new all the time. Maybe there is somebody else out there that could shed some light on this why Ruston had used a spring in the filter then not used it.
Old 04-10-2018, 03:03:09 PM
gozoish gozoish is offline
hey guys, i am looking for an injector nozzle for a ruston 1yhr because the holes on it are clogged and cant seem to find a thin wire to open them up.
thank you all for advices
david
Old 04-16-2018, 12:54:52 AM
Oil Power Oil Power is offline
Default Re: 2x hr Injector Ruston Hornsby 13 hp
I would take the nozzle to your nearest fuel injection specialist and ask to have the holes cleared. They can usually be pricked using the correct wire in holder. Also a turn in an ultrasonic cleaner may help. If you find a source for obtaining these nozzles I would be interested to know.
Hugh
Ruston Hornsby APB sunshineman Smokstak Down Under 1 03-22-2017 04:48:30 AM
Ruston Hornsby Darryl Smokstak Down Under 39 03-09-2016 04:22:10 AM
Ruston Hornsby 2.5hp AP Bazbuts Antique Gas Engine Discussion 12 06-14-2012 08:42:16 AM
ruston &hornsby 1xhr injector ? Jean DesJardins Antique Gas Engine Discussion 3 03-06-2012 08:50:50 AM
Ruston Hornsby injector repair Doug Beekman Vintage Diesel and Oil Engines 1 08-15-2007 02:33:41 AM
