Cockshutt 40 push rods.
this thread has 3 replies and has been viewed 966 times
Old 09-29-2015, 08:28:54 PM
Wayne Riedlinger Wayne Riedlinger is offline
Default Cockshutt 40 push rods.
Last Sunday we put a Cockshutt 40 with newly rebuilt engine from top to bottom on the dyno.It started missing on #2 right away. After trouble shooting we found a bent push rod and broken rocker. Clearence was set to 12 thou cold. After putting other push rods in and setting it to 14 thou cold and dynoing it for a couple hrs we pulled of the cover to reset the tappets and found a couple push rods bent a bit. The rods aren't new but the valve springs are new.I thought maybe the springs are to strong,and the push rods just too weak.. There was bent push rods in 3 other old engines my brother pulled apart. Any one else experience this sorts thing on these old Budas.
Old 10-02-2015, 09:11:07 AM
Brasherman Brasherman is online now
Default Re: Cockshutt 40 push rods.
That's a very odd problem. What were the open spring pressures on the old vs new springs? Does it have new valves? Usually when I hear those symptoms I suspect the replacement springs are thicker wire and are experiencing coil bind at max valve lift or the retainers were replaced and they have a taller neck inside and hit the valve guide. I suppose the valve guides could be too tall as well; they make guide cutters for just such a purpose.
Old 10-02-2015, 12:00:14 PM
I'm not sure about the spring thickness. I would think that the steel in the new springs would be much better then to originals. You give some very good suggestions and I will see what he has came up with if anything yet.
Old 10-09-2015, 10:05:12 PM
Glad I could offer some suggestions. Hope they help. It's pretty easy to see bind when rolling the motor over by hand. Good luck with it!
Farmall 350 Diesel Head Gasket and Push Rods Needed Bill Lloyd Antique Farm Tractors 10 03-14-2014 08:14:54 AM
1940 Farmall B push rods question Blackriver Antique Farm Tractors 3 09-15-2013 12:27:59 PM
Wanted: McCormick Deering 10-20 Push Rods junkyard4$ Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-26-2012 09:58:26 AM
Homemade Push Rods Virginia Mike Antique Gas Engine Discussion 5 10-11-2007 08:18:36 AM
