will a mx321 voltage regulator work in a 30 ek onan machine?
this thread has 7 replies and has been viewed 921 times
Old 12-09-2015, 06:23:30 PM
1baker016 1baker016 is offline
Default will a mx321 voltage regulator work in a 30 ek onan machine?
I have a free MX 321 voltage regulator that came out of a working 150 kW Onan Cummins generator and I'm wondering if I can use it in a 30 ek generator brushless style 12 lead reconnect able 3 phase and single phase output Generator
Old 12-09-2015, 09:32:10 PM
Billy J Shafer's Avatar
Default Re: will a mx321 voltage regulator work in a 30 ek onan machine?
I will check but I don't recall that it will. It is for a PMG system.
Old 12-10-2015, 12:08:14 AM
Thanks for the reply, yeah I knew it was for the pmg but was hoping the input parameters overlapped between the two generators. Even if I have to run them through a step up or down transformer. Just seems like a more robust unit than the options I have on the EK.
Old 01-22-2016, 05:01:35 PM
Bill, any luck? Thanks Dennis
Old 01-22-2016, 07:12:01 PM
Been having that debate with a fellow tech. He thinks it will with some terminals not used. I don't think it will without the isolation transformer and P.M. stator leads. He says he has one to try. Still waiting on him to get back with me.
Old 01-27-2016, 12:12:47 AM
Awesome thanks so much for your help, I have an original voltage regulator board that needs repaired a newer updated board that requires a little rewiring (don't have the instructions for the upgrade kit) and this new style board. So if there were any retrofitting I'd like to use the mx board.
Old 02-01-2016, 09:59:41 PM
Hey Billy, I hope your weekend was a good one. Have you had a chance to hear back from the other tech friend on the mx board? Just saw that you were on and figured I ask. Thanks
Old 02-01-2016, 10:43:09 PM
Last I heard it didn't work. But knowing Tim he will make it work or blow it up.
Onan Voltage Regulator, Have you ever seen one of these? fabdaddy Onan Generators 11 03-04-2018 06:23:21 PM
Will a MX321 work on a 30EK brushless? 1baker016 Generators & Electric Motors General Discussion 0 12-08-2015 10:26:44 PM
200DGFC with MX321 volt. reg. - voltage problem Chris Schmidt Onan Generators 5 03-07-2014 08:12:33 AM
Onan JC with no Voltage Regulator flagmaster Onan Generators 29 10-22-2013 07:42:06 PM
Looking for Onan voltage regulator rwenig Onan Generators 0 12-23-2004 11:38:42 AM
