271 injectors
this thread has 4 replies and has been viewed 840 times
Old 02-15-2016, 11:01:18 PM
ckelp ckelp is offline
Default 271 injectors
so the deal is the injectors where stuck solid so i pulled them and pulled them apart to clean them out and my dumas did not make a mental note of the plunger location vs the rack position :facepalm: any one can help?
Old 02-15-2016, 11:36:50 PM
Clayton Clayton is offline
Default Re: 271 injectors
Maybe this will help.....http://www.green-trust.org/photoalbu...20part%201.pdf
Old 02-15-2016, 11:45:02 PM
nope, its in the injector
Old 02-16-2016, 01:13:56 AM
John Yardley John Yardley is offline
If you look closely you will see a small dot on the pinion and two small dots on the teeth of the rack, line them up and then align the flat on the plunger with the flat in the pinion. Unless the parts are corroded the dots should be evident. The dot on the pinion is directly opposite the flat that is in the bore of the pinion. (The dots are engraved) Here is a GM 71 manual on line gives a complete breakdown that may help.
http://www.whaleboat.us/.../detroitd...ancemanual.pdf
http://www.whaleboat.us/download/det...ancemanual.pdf
The Following User Says Thank You to John Yardley For This Post:
Old 02-16-2016, 01:55:31 AM
thats more info on the 71 series then i ever wanted lol
thank you
NOP for injectors in a TD-9 IHC a jossund Vintage Diesel and Oil Engines 1 11-15-2012 05:35:11 PM
NOP for injectors in a TD-9 IHC a jossund Antique Farm Tractors 7 11-15-2012 03:44:55 PM
Injectors miwbjs Steam Stationary Engines, Traction Engines, Steam Boats 8 11-29-2011 11:56:08 PM
Injectors? Andrew Steam Stationary Engines, Traction Engines, Steam Boats 9 07-03-2008 10:02:01 AM
NEED 3/8 INJECTORS Mark Ilg Steam Stationary Engines, Traction Engines, Steam Boats 0 02-28-2002 11:34:55 PM
