Fairbanks Morse 4 Cylinder 32E14 Engine
this thread has 86 replies and has been viewed 13188 times
Old 03-20-2016, 05:33:48 PM
artc artc is offline
Default Fairbanks Morse 4 Cylinder 32E14 Engine
There was a thread (I believe) in 2004 that detailed our getting these engines from the New Britain Water Works. These engines were installed around 1938, and provided water to the city during the war. shortly thereafter, electricity was brought to the area and the engines were put on standby. An upgrade to the facility made these engines obsolete, and QVEA / Zagray Farm Museum was contacted to see if we wanted them. A huge project to be sure to get these engines out of the building they were in and out to the farm. Here are a few pictures of that move from 2004.
ID:	249406   Click image for larger version
ID:	249407   Click image for larger version
ID:	249408   Click image for larger version
The Following 8 Users Say Thank You to artc For This Post:
Old 03-20-2016, 05:41:19 PM
Default Re: Fairbanks Morse 4 cylinder 32E14 engine
Fast forward to 2016. I can't believe 12 years have passed! our struggles to carve a place for our group at he Farm is a topic we'll talk more on later, but suffice it to say that we had serious obstacles to overcome to get to where we are today. Here are a few more pictures of the engines. The 3 cylinder has been sold to a collector out of Virginia, and will be loaded on a trailer in the next month or two to send to him. We are keeping the 4 cylinder, and are currently building a foundation and a building to house this engine as well as our Atlas Imperial engine (on another thread in the forum), as well as several other interesting engines. More on that as we progress.
ID:	249410   Click image for larger version
ID:	249411   Click image for larger version
The Following 3 Users Say Thank You to artc For This Post:
Old 03-20-2016, 06:19:03 PM
I mentioned in the Atlas thread I should start one on the other engine we have been working on and Art beat me to it. As Art said the story about this engine acquisition is long and complicated. Once we were given the pair we had to completely dismantle them inside a depression building and get them ready to be moved to the farm. 12 old men spent a summer getting the job done. We took all the external parts off and hauled them in small loads to the farm 40 miles away. Once the 2 engines were ready for the more we waited for the demo construction company to remove the building around them. We finished in August but didn't get the call for the move till mid January on a day it was Minus 5 degrees outside. A local heavy equip moving company donated 2 trucks and a 60 ton mobile crane to relocate the engines to the farm. When we got to the site that morning we were surprised to find the 2 engines sitting in the middle of a snow covered field since the building and everything around it had been leveled to the dirt.
Jump ahead 12 years and we are finally are ready to get the 4 cylinder mounted in a building and running again. The pictures that follow will follow our work on this project to the end. The first 3 pics show the progress on the foundation for big engine. The hold down structure is now set in place and foundation walls setup around it. The last pic shows the 18 inch air intake pipe that must have a 90 degree angle setup done on it. You will note we are mounting this engine on a complete original concrete foundation. We are using an original set of plans given to us when we picked them up. Ed B
ID:	249419   Click image for larger version
ID:	249420   Click image for larger version
ID:	249421   Click image for larger version
The Following 2 Users Say Thank You to Ed Bezanson For This Post:
Old 03-20-2016, 06:41:55 PM
Old 03-21-2016, 10:22:22 AM
Here are a couple of pictures from Saturday. Ed figured out how to cut the pipe on a 45 degree angle. it's actually a straight cut, but has to be laid out as an ellipse on the pipe. This pipe has sat here all winter while we all scratched our heads as to how to mark it to get a half decent cut. We considered just buying an elbow for the pipe, but the best price i could get (by having a friend in a municipal water works call) was $590. the pipe was over $300 as it was.
This weekend we will hopefully complete the fabrication of forms and the placement of the mounting bolts for the alternator and outer bearing.
There will be a third pour on this engine foundation to get to the level of the engine bolt tubes, but that will be easy by comparison.
Name:	fairbanks 3-2016 218.jpg
ID:	249472   Click image for larger version
Name:	fairbanks 3-2016 220.jpg
ID:	249473   Click image for larger version
Name:	fairbanks 3-2016 223.jpg
ID:	249474   Click image for larger version
Name:	fairbanks 3-2016 229.jpg
The Following User Says Thank You to artc For This Post:
Old 03-21-2016, 07:55:52 PM
So as Art mentioned above how do you cut a perfect 45 Deg. Angle on a 18 3/4 inch diameter. I made the mistake last week to go up to the farm on Wed. and Art said take the big pipe home and put a 90 Degree on it. If you had a huge chop saw it would be a piece of cake but no such luck. I was forced to go online where I found dozens of ways to do the job. Some are quite complicated requiring a lot of math. [took that 60 years ago] so looked at other options. The one I ended up with used a little math but seemed straight forward. It took 3 hours to draw it out on a large sheet of paper and then transfer measurements to a flat surface to form a parabolic curved oval. When cut out and wrapped around the pipe it should give you the line at a 45 angle that can then be cut. I didn't like how it looked so went back to the net. that's when I found a guy who said it can be done in 3 simple steps. Followed his directions and in 15 minutes had a full sized cutout ellipse template. Next morning went down to the pipe and wrapped the big layout around the pipe and did not like how it looked. You only get one chance to cut into a $300 pipe. I then decided to slide the cardboard ellipse around the pipe and voilą it fit perfectly. I drew the line with a marker and got ready for the cut. I cut the sides with a skill saw but finished the top and bottom with a sawsall since the cut had to be on a 45 degree angle.. Pics. show the results of all this layout. The end cut wasn't perfect but fine for what we are doing. I ended laying a 4 inch wide stainless sheet metal band around the cuts and bolted it with about 4 3/8 bolts threaded into the 1 inch thick pipe. a side note here is that all the tutorials on the web were for 3"-4" pipe and easy. When you move out to nearly 19" it is a lot harder.
Pic No 1 shows the simple drawn and cutout ellipse which was transferred to cardboard for final template. Pic No 2 is the much more complicated one piece wrap around template that didn't work out so well. The last pic. shows the cardboard template slid over the pipe ready to mark. Good luck if you ever have to do this job. It isn't impossible but does take a bit of perseverance. Ed B
ID:	249519   Click image for larger version
ID:	249520   Click image for larger version
The Following User Says Thank You to Ed Bezanson For This Post:
Old 03-23-2016, 06:45:50 PM
Ed tells me that he has the alternator and the bearing bolt setup completed, even though he had to go in for a prostrate biopsy, which must be a blast! Hope i skip that one!
over the weekend we will get this form to the point of pouring concrete. that is, after we all go over the measurements to be certain they are correct! fingers crossed!
Old 03-24-2016, 11:07:45 PM
The following set of pics took about 10 hours of layout and fabrication time. I started with 2 - 8 foot lengths of heavy 3x3 Angle iron and progressed from there. Pic No 1 shows the 18 inch long bolts that will eventually hold down the 2 heavy alternator plates. I made them by welding 7/8 bolts to each end of heavy wall 11/2 inch pipe. Full length bolts would have been very costly. Pic No 2 is another view of the fabrication. Pic No 3 is long view of the pair of holddown fixtures. Last pic show the 21/4 pipes welded around the bolts so they will room to move around once the concrete is poured to allow for movement. This fixture will be completely covered with cement with only the top 4 inches of bolts showing. Ed B
ID:	249746   Click image for larger version
ID:	249747   Click image for larger version
ID:	249748   Click image for larger version
Old 03-24-2016, 11:17:25 PM
This set of pics show the boltdown fixtures set down in the forms. Pic no 1 is long view of whole form setup around the eventual Fairbanks Morse base with the Generator setup at the far end. Pic No 2 is a view looking down into the forms with the 2 fixtures in place. This Saturday we will spend a lot of time getting this setup in its exact position for a future pour. Art says 3 different people will follow the plan layout dimensions to be absolutely sure everything is in its proper position before we seal it up with 25 yards of concrete. Ed B
ID:	249750   Click image for larger version
The Following 4 Users Say Thank You to Ed Bezanson For This Post:
Old 03-25-2016, 10:20:38 AM
con-rad con-rad is offline
Looks like you guys are getting some good headway! I have to start coming up on weekends again now that the weather is good.
Kind of late, but I cut some nice 45 degree cuts on exhaust pipe easily by printing out a sine curve where the length of the curve was the circumference of the pipe and the amplitude was the diameter. wrap it around the pipe and cut.
https://www.youtube.com/watch?v=1jLW...YTuQl8YkvKU16Z
Connor
Weight of a Fairbanks 32E14 CatoeFarms Antique Gas Engine Discussion 2 05-10-2016 08:26:19 PM
Fairbanks Morse vertical cylinder 3x3 1/2....is it an engine? compressor? A pump? leeg Unidentified Engines 5 07-02-2013 01:27:23 AM
Fairbanks Morse single cylinder engine value troyjohnson Vintage Diesel and Oil Engines 4 09-25-2012 06:25:47 PM
3 cylinder and 2 cylinder Fairbanks Morse Diesels Randy L Peterson Vintage Diesel and Oil Engines 0 09-14-2011 01:23:46 PM
Two Cylinder Fairbanks Morse Larry Kastens Antique Engine Archives 0 02-17-2001 11:13:43 PM
