Water Cooled Briggs & Stratton? What model?
this thread has 8 replies and has been viewed 1789 times
Old 04-09-2016, 06:22:06 PM
Vanman Vanman is online now
Default Water Cooled Briggs & Stratton? What model?
A little out of place putting this in the Small Air Cooled Engine category, but I couldn't find a Water Cooled Briggs and Stratton section I saw this in a guy's garage today and it has left me rather perplexed. I didn't buy it, I'm not even sure if it's for sale, or, if so, for how much.
I looked it over thoroughly and found no nameplate. It's got a flywheel with no fan blades, and a tiny little belt driven water pump! No radiator, perhaps it was marine?? It has no air cleaner, and it has very little compression. Perhaps those two conditions are related
Obviously the little fuel tank is not original.
It *looks* a lot like the ZZs I've been working on lately, except of course it has a water jacket instead of fins
So what is it?
ID:	251093   Click image for larger version
The Following 9 Users Say Thank You to Vanman For This Post:
Old 04-09-2016, 08:33:50 PM
Jonathan Widelo's Avatar
Default Re: Water Cooled Briggs & Stratton? What model?
Neat piece ! I bet your getting a lot of emails and messages about this ! It is a very unique item. looks like a model Z or something like that, most likely uses on a small boat as propulsion ! I have a NPW on a small generator unit. They are a very cool unique unit ! If I was you I would get it !
~ Jonathan
Old 04-09-2016, 09:33:54 PM
Junkologist's Avatar
Images: 160
Very cool piece! First one like it I have seen. I've seen quite a few NPWs, but never one like that. May have been part of a marine genset. The propulsion units usually have an angled base on them.
Mike
SmokStak member #146
Old 04-09-2016, 11:48:06 PM
gambitace71 gambitace71 is offline
That is a model Z briggs Water cooled made by Universal engine.Google search gravelyguy.com There is model Ns and a model 8.thanks for the pictures.
The Following 3 Users Say Thank You to gambitace71 For This Post:
Old 04-10-2016, 08:40:15 AM
grega's Avatar
grega grega is offline
Images: 106
As said it is a water cooled ZZ. I would love to have one.
-Greg
"There only origionial once"
The Following User Says Thank You to grega For This Post:
Old 04-10-2016, 08:07:16 PM
Fred Van Hook's Avatar
Images: 480
Photo Re: Water Cooled Briggs & Stratton? What model?
NPW-102 Water Cooled Briggs
https://youtu.be/QCTvOGFL2do
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following 2 Users Say Thank You to Fred Van Hook For This Post:
Old 04-11-2016, 02:03:14 AM
Based on the responses seen here, it would seem to be the general consensus that I should try to acquire this engine
It would be nice to be able to provide electricity AND heat during a power failure
I have a feeling the fellow may want quite a bit of money for it, but I could be wrong. What do you guys think would be reasonable?
Bear in mind again, that it's missing it's air cleaner, original fuel tank, and some of the governor linkage. And it has almost NO compression at all. Don't know if the mag is good...
I assume these never had radiators, instead expected to connect to what ever was handy?
Keith
Old 04-16-2016, 12:46:32 AM
Well, I ended up snagging the water cooled ZZ today Here's a photo of it in the truck. When I get to working on it (a few projects partially taken apart are ahead of it already ) I'll start a proper thread for it. This post is just to provide closure to this thread
Thanks for all the input,
Keith
The Following 5 Users Say Thank You to Vanman For This Post:
Old 04-16-2016, 12:11:20 PM
OTTO-Sawyer's Avatar
Interesting engine !
Glad to see you got it. Looking forward to the rebuild thread on it.
Briggs & Stratton 19.5 HP - Turbo Cooled SteamTractors Garden Tractors / Mowers / Scooters 5 10-06-2011 11:00:25 AM
Briggs water cooled decal? gambitace71 Small Air Cooled Gasoline Engines 0 01-22-2010 10:11:04 PM
Water cooled Briggs Fred Van Hook Small Air Cooled Gasoline Engines 5 05-31-2008 12:02:21 AM
Water Cooled Briggs Engine Jim Metzger Small Air Cooled Gasoline Engines 7 08-19-2007 11:41:48 PM
water cooled briggs generator? turbo Small Air Cooled Gasoline Engines 3 02-05-2007 11:40:32 PM
