Model 72 fuel drain plug.
this thread has 3 replies and has been viewed 934 times
Old 04-10-2016, 02:06:41 PM
Blackbeard Blackbeard is offline
Default Model 72 fuel drain plug.
I just picked up a model 72 twin. The fuel tank is salvageable, but the drain plug has a pin hole right in the center of it. I suppose I could drill and tap it to fit a 1/4 npt plug, but I'd rather just have a good plug. If anybody has an extra one please let me know. Thanks.
Old 04-10-2016, 08:49:14 PM
Default Re: Model 72 fuel drain plug.
We're assuming you have the alunimum tan,, and not the cast iron one.
Old 04-10-2016, 10:48:51 PM
That is correct.
Old 04-22-2016, 10:44:57 AM
You might check with Tom S or Mark Shulaw (Maytag Mark), here on the Stak.. One of them probably has a plug if you don't have one already.
onan bhe 6.5 oil drain plug? kosmo101 Onan Generators 7 09-05-2013 10:10:29 AM
Onan 4KY Oil Drain Plug Size justgurn Onan Generators 4 05-08-2013 01:57:37 PM
F/M ZD water drain plug ? Toolbender Antique Gas Engine Discussion 5 07-04-2012 10:48:28 AM
Model 92 Drain PLug/drain hole - thread size? redr2 Maytag Engine Collectibles 8 03-17-2010 11:13:56 AM
Maytag Drain Plug MaytagRepairMan Maytag Engine Collectibles 0 08-01-2009 11:48:51 PM
