Maytag Upright - HELP *asking*
this thread has 5 replies and has been viewed 1441 times
Old 05-11-2016, 09:49:41 PM
MiqC2001 MiqC2001 is offline
Images: 1
Default Maytag Upright - HELP *asking*
Hi,
I find this engine... I don't at 100 %it's a Maytag... ? An Elgin ?
Thanks for your help !
Charles
ID:	253574   Click image for larger version
ID:	253575   Click image for larger version
ID:	253576   Click image for larger version
Old 05-12-2016, 01:11:52 AM
turbo's Avatar
turbo turbo is offline
Default Re: Maytag Upright - HELP *asking*
Definitely an Elgin. Very nice engine there!
The Following User Says Thank You to turbo For This Post:
Old 05-12-2016, 03:31:17 AM
Images: 1
Do you know the model, year and others informations on this engine ?
Many thanks,
Charles
Old 05-17-2016, 10:45:54 PM
Kevin Weis Kevin Weis is offline
Serial number should be on side of hub if it hasn't been molested. If serial number is on face of flywheel than may be some parts of it are Maytag. But it does look all Elgin.
Kevin
Old 05-18-2016, 09:37:48 PM
enginesilo's Avatar
enginesilo enginesilo is offline
Like others have said, definitely looks like an Elgin. As seen here
Notice the carb is different from the Maytag upright carb variations. Also, the castings and shape of some areas looks slightly different.
Tom S posted a nice write up on early Maytag Uprights which starts with an Elgin like yours, check it out here:
http://www.smokstak.com/forum/showthread.php?t=60047
And here is another which shows some Elgins in the 1HP Write up:
http://www.smokstak.com/forum/showthread.php?t=61700
Nice find.
Old 07-20-2016, 11:12:16 PM
Tom S's Avatar
Tom S Tom S is offline
Nice find! you don't run across those very often!
Maytag Upright ksbowhunter Scale Model Engineering 2 09-11-2014 08:51:08 PM
Maytag Upright Brian.P Maytag Engine Collectibles 10 06-13-2011 10:08:05 AM
Maytag Upright MedicHamilton Maytag Engine Collectibles 1 01-19-2011 10:36:18 PM
Maytag Upright 1hp With Mag - need help Mike Grivna Maytag Engine Collectibles 7 11-07-2007 11:20:07 PM
Upright Maytag Ed Kinch Antique Engine Archives 0 11-23-2001 01:32:14 PM
