Wisconsin Engines
Wisconsin BKN - sparkplug location difference
this thread has 2 replies and has been viewed 967 times
Old 06-05-2016, 10:59:32 PM
oldiron1 oldiron1 is offline
Default Wisconsin BKN - sparkplug location difference
Hi Guys, I have two garden tractors that I'm trying to date, both have Wisconsin BKN engines however neither one has a tag anymore unfortunately. One difference between the two that I noticed is one sparkplug installs vertically in the top of the head while the other is on a 45 degree angle. Any idea when that change occured?
Thanks, Rob
---------- Post added at 09:59:32 PM ---------- Previous post was at 09:11:14 PM ----------
I just noticed now one more difference; the engine that has the spark plug on a 45 degree angle, the exhaust port comes directly on the side, perpendicular with the crank shaft; not on an angel like the other engine. Otherwise the engines look similar; square gas tanks with the same bracket, magneto and oil bath air cleaner which look the same. Maybe they're not both BKN's?
Old 06-06-2016, 06:45:04 PM
Zira Zira is offline
Default Re: Wisconsin BKN - sparkplug location difference
The angled one is an ABN or AKN (or earlier AA, AB, or AK). so older than the BKN (or ACN) on the other one.
The Following User Says Thank You to Zira For This Post:
Old 06-07-2016, 12:30:03 AM
Thanks! What's strange to me is this engine is 1 little more than an inch longer than the AK and ABN engines I have on other tractors. The flywheel is exposed behind the shroud similar to the BKN? On my other Page tractor.
ID:	255668   Click image for larger version
Difference between Wisconsin BKN & AENL BlkBeard Wisconsin Engines 3 06-07-2013 07:42:00 PM
Difference between Wisconsin TF and TH Monte Stock Wisconsin Engines 2 06-30-2008 10:12:38 AM
Difference between the Wisconsin TF and TE Monte Stock Wisconsin Engines 0 06-29-2008 07:44:54 PM
What is the difference in Wisconsin ABN and AKN bouncingbennyboy Wisconsin Engines 2 06-12-2008 10:13:39 PM
Difference between the Wisconsin TF and TE Monte Stock Wisconsin Engines 1 10-24-2007 07:32:07 PM
