Maytag 72 bushing tolerance.
this thread has 1 replies and has been viewed 892 times
Old 06-16-2016, 08:23:19 PM
W Grile W Grile is offline
Default Maytag 72 bushing tolerance.
I'm getting ready to ream the bushings for the crankshaft with an adjustable dreamer. What sort of tolerance do I need to hold?
Old 06-20-2016, 06:49:55 AM
Clement Rook Jr. Clement Rook Jr. is offline
Default Re: Maytag 72 bushing tolerance.
w grile, the bushings should be one to two thousands bigger than the crank shaft .i have found that a better option than reaming is to take your main bearing to a machine shop that has a sunnen hone machine and have them hone the bushings to a perfect fit. well worth the cost.
clement
The Following User Says Thank You to Clement Rook Jr. For This Post:
Maytag 82 con-rod bushing Gilbert_Bates Maytag Engine Collectibles 6 12-29-2014 08:30:12 PM
acceptable tolerance between wrist pin and bushing? con-rad Antique Gas Engine Discussion 2 06-24-2013 10:16:47 PM
rod bearing end play tolerance? Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 01-31-2012 08:56:39 PM
Bearings and Bushings fit Tolerance Elwood Antique Gas Engine Discussion 4 05-05-2011 09:39:27 AM
