Maytag 82 rod bearing help
this thread has 2 replies and has been viewed 829 times
Old 07-28-2016, 06:50:38 PM
Default Maytag 82 rod bearing help
My Maytag Has a lot of play in the connecting rod. There is no bushing or rod cap. The crank measures .619" and the rod ID is .648". It sure feels like more than that when turning the flywheel. What is the Best/easiest way to fix it? Ron
Old 07-29-2016, 10:33:17 AM
turbo's Avatar
turbo turbo is offline
Default Re: Maytag 82 rod bearing help
.029 play is A LOT!! Almost all engines run no more than .003. The only proper way is to have the crank pin trued and a new rod and wrist pin made. I have tried bushing the rod with limited success. There is really not enough material on the rod. The bushing is so thin that with enough run time will try to walk out. If anyone else has bushed these with success I would love to hear how to do it. The only thing I have not tried is silver soldering the bushing in. I have a couple uprights with sloppy rods that I might try this method.
The Following User Says Thank You to turbo For This Post:
Old 07-29-2016, 10:49:01 AM
Arlie Levy Arlie Levy is offline
I took my uprite to an automotive machine shop and they built up the crank shaft and refit the rod . worked real good. cost was around $90.00. good luck.
The Following User Says Thank You to Arlie Levy For This Post:
Maytag Upright, carb on bearing Everett Hayden Maytag Engine Collectibles 3 10-27-2015 06:51:53 PM
maytag 82 main bearing Clement Rook Jr. Maytag Engine Collectibles 0 05-24-2012 03:03:42 PM
Maytag 92 main bearing clearance Gilbert_Bates Maytag Engine Collectibles 4 12-20-2011 03:11:23 AM
maytag 82 main bearing repair mrtowmanalan Maytag Engine Collectibles 5 10-16-2011 02:08:39 PM
Maytag 72 Bearing Tolerances ajs2001tx Maytag Engine Collectibles 1 12-29-2008 05:10:07 PM
