Cummins HB new to me, maybe early 1945, photos
this thread has 26 replies and has been viewed 3816 times
Old 07-11-2017, 11:38:11 AM
mschreiber mschreiber is offline
Default Cummins HB new to me, maybe early 1945, photos
Been told its a HB, whats that mean? I don't know diddley bout cummins but I like it. I think its a power unit orignally used on a machinery, not truck? Its got block casting date 2-14-45. Please comment with any info u can, looking 2 learn. As shown weighs 3700 lbs. thanks 4 looking.
The Following 7 Users Say Thank You to mschreiber For This Post:
Old 07-11-2017, 03:11:52 PM
Ed Noli's Avatar
Ed Noli Ed Noli is offline
Default Re: Cummins HB new 2 me, maybe early 1945, photos
Some info I have. Must have been upgraded to the newer style pump at some point in its life.
The Following 2 Users Say Thank You to Ed Noli For This Post:
Old 07-11-2017, 06:01:10 PM
yes its has, its a good thing i've read so far.
serial number is 51210 or C instead of 0. thanks 4 looking.
Old 07-11-2017, 11:06:25 PM
dieselsteveo dieselsteveo is offline
That a great looking engine. Is it the same one that was for sale on EnginAds 1-2months ago? Looks similar....
Anyways, serial # 51210 would've been build in the first few weeks of July 1945. I will look to see if we have the build records for it. It is a Model H, and as Ed mentioned, your engine would've been built with the Single Disc fuel pump, and has been upgraded to the PT fuel system which came out in 1954. This is a very common upgrade and I'm sure you'll enjoy it more with PT. As far as the B in the HB name, I'm spacing out on what it stands for. We had HA's, HB's, HMR's, and then when we added super-charging and other configs the names got even longer and a bit out-of-control Sometimes the second letter refers to the application (eg: HMR's are marine), but HB's were used in both auto and industrial so B doesn't equal application.
It appears your engine has an air compressor in front of the fuel pump?? Am I seeing that correctly? The skid is also atypical with that large arch on the manifold side. If I had to guess, this unit was probably in a construction application (eg: shovel, crane, etc). Hopefully the build records will shine light on this.
We have full sets of manuals for this engine, so if you ever need any info, let me know. I can't/won't scan the whole manual for you - but happy to scan sections.
Cheers,
Steve
Cummins Historical Team Lead
The Following 5 Users Say Thank You to dieselsteveo For This Post:
Old 07-12-2017, 02:49:33 AM
Originally Posted by dieselsteveo View Post
That a great looking engine. Is it the same one that was for sale on EnginAds 1-2months ago? Looks similar….
***yes bought it from the ads, thanks harry!
****i forgot what zack said about it. its at my sons shop, i'll get better pics soon.
***** it looks 2 me the skid was torch cut from the original equipment frame structure that held the unit. I agree shovel, crane, etc.
*****thank u, waiting 4 what build record may indicate. I'll be fixing it up, detailing it cherry along with replacing missing hood and side covers. it'll be 4 show, maybe sawmill or rockchrusher work at our local show.
Cheers,
Steve
********mike
Old 07-12-2017, 07:41:24 AM
How difficult would it be 2 find a oil pan for this? i'm going to drop it to disludge it. Its been busted and brazed up big time, but not leaking. Would new pan gaskets be available?
thank u
Old 07-12-2017, 10:12:33 AM
ronm ronm is offline
Default Re: Cummins HB new to me, maybe early 1945, photos
That is a nice engine. Good you were able to save it...
Smokstak member #442
Old 07-12-2017, 03:57:20 PM
I was close. Your engine was built July 6, 1945, tested July 7, 1945, and shipped to "Diesel Sales Company of Wisconsin" on July 18, 1945. It is listed as a "PD" application, which is a power unit, probably for drilling oil/gas. I found some photos that show other power units, all being using for oil/gas applications. They show the hood, the louvered side covers, the fuel tank that was mounted where your air cleaner currently is...and a few of the photos show engine mounted on the same skid/rails that yours is mounted on. Your engine was not built with an air compressor, so whatever is in front of your fuel pump was added later on.
The build record and photo files are bigger than what the forum will allow me to upload so I've uploaded them here: https://drive.google.com/open?id=0B6...WtJaXJnMGpaV00
The Following User Says Thank You to dieselsteveo For This Post:
Old 07-12-2017, 05:45:08 PM
So its a "HPD-600"? What does revision "B" mean on the spec sheet? I'm surprised the skid may be original as its rather crudely torched to size. Dingleberries/slag not scraped off. Not complaining i'm happy with how complete it is. Not much gas/oil in wisconsin but a lot of water with channel cleaning required, stone and sand quarries needing power. maybe a pump power unit of some type.
Arched cutout in skid may be 4 a oil drain pan?
thank u.
p.s. i just now scrolled up enough to see second build sheet page.i'll have to see if serial numbers match on the starter, generator and pto.
thanks again.
Old 07-12-2017, 08:57:33 PM
halcon halcon is offline
Most of the larger cranes and shovels had air assisted controls. That could explain the compressor.
The Following 2 Users Say Thank You to halcon For This Post:
Cummins L423D starting problems (Cummins A Series) ichudov Onan Generators 12 08-11-2018 12:00:38 PM
IHC lb 3-5 1945 ti-jean Antique Gas Engine Discussion 5 01-11-2015 09:21:25 AM
Rock River Thresheree 2013 photos, Many early Cases Paul Searl Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 09-06-2013 11:21:43 PM
1945 cummins A 1 military 32 volt HELP californicate Vintage Diesel and Oil Engines 7 12-26-2011 03:10:16 AM
Early IHC Photos John Merry Antique Gas Engine Discussion 6 02-26-2008 06:37:31 PM
