Cummins HB new to me, maybe early 1945, photos
this thread has 26 replies and has been viewed 4089 times
Old 08-10-2017, 12:28:57 PM
Vanman Vanman is offline
Default Re: Cummins HB new to me, maybe early 1945, photos
I do know that the "N" designates four valves. I have one. Well two, but one running. And it is the 5-1/8" bore, 743 ci.
Old 08-10-2017, 03:10:28 PM
dieselsteveo dieselsteveo is offline
Here's our family tree - hopefully this will help clarify things a bit...or muddy the waters it could go either way
The HB is a revision to the model H and it happened very early on in the life of the H. The very early H (1932-1935) had babbit bearings, different diameter crank journals, different pistons, 4 7/8" bore 6" stroke. In 1935, the revision B was released that switched to modern serviceable bearings, larger crank journals, and an increased rating.
The NH came out in 1944, with the 4-valve head, new block, new other stuff, 5 1/8" bore 6" stroke. To confuse everyone, we also bored the H to 5 1/8 and called it the HR.
In 1957 we bored the engine again to 5 1/2" bore 6" stroke and called in the NTC855, along with other upgrades. The H was obsoleted, and the NH was bored to 5 1/2".
1970-75 we made the N-927, which had a 5 1/2" bore 6 1/2" stroke.
Then finally in 1990 we updated the engine one last time to the N14.
And all this doesn't include all the variations for supercharged, turbocharged, horizonal, or V versions of the H family.
The Following 4 Users Say Thank You to dieselsteveo For This Post:
  #23
Old 12-08-2017, 03:52:41 PM
mschreiber mschreiber is offline
different photo.
Old 05-20-2018, 08:27:20 PM
My cummins power unit finally at home shop. Gonna make new hood and louvered side panels along with firewall fuel tank and battery shelf. its runs good and gonna trick detail it out like my other projects. thanks 4 looking.
sock oil filter, i may want to eliminate this and go with spin on remote.
The Following 3 Users Say Thank You to mschreiber For This Post:
  #25
Old 05-20-2018, 08:35:54 PM
Sooty Jim Sooty Jim is offline
Great to see it again! A piece of history, for sure!
The Following User Says Thank You to Sooty Jim For This Post:
  #26
Old 05-20-2018, 08:54:01 PM
Heres a era photo of hp's steve sent me. What is that disk on vertical shaft? remote throttle control? thanks 4 looking.
---------- Post added at 07:54:01 PM ---------- Previous post was at 07:40:17 PM ----------
more from steve.
anyone got a extra ail filter like that available?
The Following 4 Users Say Thank You to mschreiber For This Post:
  #27
Old 05-21-2018, 12:00:49 AM
The disc on the vertical shaft is definitely for throttle control.
Not that its of any help, but the extra air filter may have been a Cummins option, possibly Donaldson brand. I know I've seen it on a number of industrial engines including the larger Model L engines.
Cummins L423D starting problems (Cummins A Series) ichudov Onan Generators 12 08-11-2018 12:00:38 PM
IHC lb 3-5 1945 ti-jean Antique Gas Engine Discussion 5 01-11-2015 09:21:25 AM
Rock River Thresheree 2013 photos, Many early Cases Paul Searl Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 09-06-2013 11:21:43 PM
1945 cummins A 1 military 32 volt HELP californicate Vintage Diesel and Oil Engines 7 12-26-2011 03:10:16 AM
Early IHC Photos John Merry Antique Gas Engine Discussion 6 02-26-2008 06:37:31 PM
