Ruston Engine Acquisition
this thread has 46 replies and has been viewed 5942 times
Old 07-31-2017, 08:32:13 AM
artc artc is offline
Default Ruston Engine Acquisition
We've been looking at this engine for a couple of years while another antique equipment museum decided its disposition.
They called us a month or so ago and told us we could have it, mostly because we have the space (or will have) to display it and willing hands to restore it.
It has some issues - a crack in the head and the belt pulley is broken and parts of the spokes are missing. We are also going to need to separate the clutch drive and the flywheel from the crankshaft in order to clean up the crankshaft and check for straightness.
The flywheel is 6 feet diameter and probably a foot wide, weighing i'm told 7000 lbs.
More pictures to follow.
The Following 3 Users Say Thank You to artc For This Post:
Old 07-31-2017, 12:54:05 PM
Card Sponsor
Default Re: Ruston engine acquisition
Is that an HR6 series engine? Likely would have an EX on the nameplate too . Rob
Old 07-31-2017, 07:15:54 PM
Jean DesJardins Jean DesJardins is offline
rob jean from quebec,i will have a very original Ruston 1xhr in portland ,any interest.
Old 08-01-2017, 08:03:21 AM
haywaj haywaj is offline
Jean I would be interested in that.
Old 08-01-2017, 09:40:13 PM
con-rad con-rad is offline
Hey all,
here are a couple more photos of us loading and unloading the engine. I have a video uploading that will be done shortly.
The head has some cracks between the cylinder head stud holes and water jacket. From what i've seen, they don't look too bad and shouldn't be too hard to seal up.
the cylinder/frame will be temporarily mounted on a cart so i can wheel it into my personal shop and pressure wash it, check out the piston, rings, bore, governor, etc. The engine has some nice pinstriping on it which i will photograph and re create when i paint the engine. I would have liked to keep the original patina and paint, but i think too much of it is gone to be worth it.
connor
ID:	287672   Click image for larger version
ID:	287673   Click image for larger version
The Following 2 Users Say Thank You to con-rad For This Post:
Old 08-01-2017, 10:18:53 PM
Card Sponsor
That engine has a removable sleeve which has an Oring at the back. Might leak Might not. You may want to pull the sleeve and change it.What size is it? HR6 HR7 ?Did you get the handcrank? I have an HR6 electric lighting and a 25 KW generator. Built in 1935. Rob
Old 08-02-2017, 11:03:45 AM
We are thinking of putting this engine in our current Engine Shed, along with the Atlas and the Fairbanks diesel engines. We have room for it, but will need to cut the floor and excavate to pour a base for the engine and flywheel support to bear on.
Now to figure out the correct dimensions to accomplish that.
We believe the engine is a 7XHR, 40HP at 300RPM.
If anyone is in the area, stop in and visit with us At the Zagray Farm Museum in Colchester, CT. PM on of us to co-ordinate.
The Following User Says Thank You to artc For This Post:
Old 08-02-2017, 03:23:32 PM
Marcel P's Avatar
Marcel P Marcel P is offline
Nice engine, I like the unloading (or was it loading) with the dragline!
The Following User Says Thank You to Marcel P For This Post:
Old 08-02-2017, 06:59:03 PM
Here is the first video of the Ruston! if i have the time, the base will go on a cart this weekend or next and come to my shop.
https://youtu.be/uUFsOeJ1wE0
Rob, thanks for the info on the sleeve o-ring. Do you know if it's something i could replace with a McMaster o-ring or similar, or is it special? And as far as a hand crank goes, i think this engine is a bit large to have one of those! It will be cranked over on air.
connor
The Following 5 Users Say Thank You to con-rad For This Post:
Old 08-02-2017, 08:01:14 PM
Contaucreek's Avatar
Contaucreek Contaucreek is offline
connor
Just grab a young friend and have at 'er. I start my Class 4 Ruston by hand crank
I was told of a Class 3 17hp here in Ontario that starts on 1/2 compression with a lit wick by rolling the flywheel over the top by hand, no crank
The Following User Says Thank You to Contaucreek For This Post:
Who has a Ruston-Hornsby engine? DirtbikePilot Antique Gas Engine Discussion 52 10-19-2015 07:36:14 PM
Ruston Hornsby 17 H.P. mill engine ? David Russell Antique Gas Engine Discussion 11 08-11-2012 02:35:32 PM
The most Amazing Sounding Ruston Engine! Skandia600 Antique Gas Engine Discussion 0 10-18-2011 07:46:16 PM
500 HP Ruston Hornsby Engine bocephus_k6 Antique Gas Engine Discussion 3 07-12-2010 11:06:47 AM
New acquisition...WONDER PUMP ENGINE. Alex F Antique Marine Engines and Outboard Motors 3 04-21-2008 08:27:30 PM
