National Gas and Oil Co MBSE 17hp
this thread has 6 replies and has been viewed 1393 times
Old 02-23-2018, 11:55:31 PM
Jake65mm Jake65mm is offline
Default National Gas and Oil Co MBSE 17hp
Well i added another national to the engine collection last weekend, its a 17hp diesel single flywheel engine designed to run a generator. I believe the paint is factory, and almost all of the serial numbers match except the big end con rod bearing.I will posting pictures soon
The Following User Says Thank You to Jake65mm For This Post:
Old 02-24-2018, 08:33:13 PM
Default Re: National Gas and oil co MBSE 17hp
here is where the old girl lived since 1984
The Following 3 Users Say Thank You to Jake65mm For This Post:
Old 02-24-2018, 08:34:20 PM
The Following 2 Users Say Thank You to Jake65mm For This Post:
Old 04-10-2018, 12:59:57 PM
Got the base built
ID:	307893   Click image for larger version
ID:	307894   Click image for larger version
Old 04-11-2018, 10:28:06 AM
kwfiggatt kwfiggatt is offline
Default Re: National Gas and Oil Co MBSE 17hp
Beautiful fab work!
Old 04-12-2018, 09:12:25 PM
Thank you!
Old 05-28-2018, 08:02:02 AM
https://youtu.be/dcMOVmPYo0A
George White 17hp ChadYelland Steam Stationary Engines, Traction Engines 14 03-27-2016 05:01:17 PM
National Coil Co. REO Car or Truck, National ignition lighting unit mschreiber Magnetos, Ignition Coils and Spark Plugs 4 02-23-2015 10:58:59 AM
17HP Ruston Hornsby CR Troubleshooting Dan Burkart Antique Gas Engine Discussion 6 09-14-2014 12:42:37 PM
17hp sawyer massey portable Andi Steam Stationary Engines, Traction Engines 0 05-25-2003 08:46:01 PM
17hp Blackstone Pix Patrick M Livingstone Antique Engine Archives 0 03-17-2003 08:54:45 AM
