Vintage Hercules V8
this thread has 37 replies and has been viewed 3831 times
Old 03-08-2018, 09:33:18 PM
12v92 12v92 is offline
Default Vintage Hercules V8
saw this on craigslist. thought someone would want it!
https://hartford.craigslist.org/hvo/...520684274.html
The Following 6 Users Say Thank You to 12v92 For This Post:
Old 03-08-2018, 10:46:50 PM
s100 s100 is offline
Default Re: vintage hercules v8
That thing is way too cool to go to the scrapper. I hope someone here sees the ad and saves the old beast. And I don't even like V8's....
Old 03-08-2018, 11:49:55 PM
dkamp dkamp is offline
eMail NOT Working
6.25" bore x 6" stroke, x 8 cyl = 1472.62 cubic inches of diesel injection, driving a 170kw generator, means it's got at LEAST 250hp at the flywheel at governed speed. I'm betting this is a 1200rpm unit... if so, that's 1100 foot-pounds of torque...
Somebody save this bugger! (wish I was there... with a STRONG trailer... )
Old 03-09-2018, 12:02:55 AM
Vanman Vanman is offline
That engine is neat, for sure, but the whole thing is COOL!!!
Old 03-09-2018, 08:33:31 AM
mschreiber mschreiber is offline
Default Re: Vintage Hercules V8
how old is it, what does it weigh?
Old 03-09-2018, 08:40:13 AM
That is just too cool and deserves a full spiff up. And I'm sure I can just saunter into the local store for parts.
Old 03-09-2018, 11:37:43 AM
It is located in Bozrah, CT between Norwich and Colchester just off Rt 2. We would love it at the Zagray Farm Museum which is 8 miles up the road. It would go great with our big Fairbanks and Atlas Imperial. Problem is we only take donations. Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
Old 03-09-2018, 12:18:00 PM
I can imagine this gem with a full Johnny C primo grade A resto.
Johnny, start a go fund me page!
Old 03-09-2018, 02:28:14 PM
Sooty Jim Sooty Jim is offline
Never seen a Herc V8 outside a very few mentions in period publications. Yeah, that one deserved to be saved!
Old 03-10-2018, 07:51:30 PM
That was made for the phone company- usually those are specified with the best of everything.
https://www.smokstak.com/forum/showthread.php?p=668972
another mention of the same model, just for reference.
Old 03-13-2018, 01:47:40 AM
Fageol100 Fageol100 is offline
I wonder if it is an overhead camshaft engine?
Old 03-13-2018, 08:53:25 PM
I was wondering the same thing. That valve cover sure looks like there's a cam hiding in there. If someone has any disassembled views, could you please scan and post a few shots?
Old 03-13-2018, 09:56:13 PM
ronm ronm is offline
The 4-cyl. injection pumps on the end of each head sorta confirm that theory...
Smokstak member #442
Old 03-14-2018, 07:45:06 AM
We all are intrigued by this lump. There are manuals for it on epay but I'm not going to pop for one. I wonder if these engines were made by another outfit and were re branded under the herc name. It seems so complex compared to the basic and almost crude nature of Hercules engines.
Aside from i's generator use, I couldn't resist plopping it into an open front end rat rod just to see the artwork of it.
Crusin down the road at 80 with that thing turning 700 rpm.
The Following 3 Users Say Thank You to I like oldstuff For This Post:
Old 03-14-2018, 08:51:53 AM
Older Hercules 4 & 6 cylinder diesels had the injectors located at the top of the block. These look to be located there too or can some one enlarge the picture to make sure.
Old 03-14-2018, 02:26:47 PM
dalmatiangirl61 dalmatiangirl61 is online now
If nobody here is going to buy it, this sounds like the next best option. Have you inquired into getting the owner to donate it? If owner needs cash I'd drop $5 in the collection hat, just need 299 more members to do the same
Old 03-14-2018, 07:28:29 PM
i talked to the guy about donating it to zagray farm, like ed mentioned 8 miles away. i gave ed his number.... hope it works out. i'm 80 mile away but don't have my big truck nor trailer with me this trip from indiana.
The Following User Says Thank You to mschreiber For This Post:
Old 03-14-2018, 09:37:43 PM
enginenut2 enginenut2 is offline
John, My catalogs 1954-1959 show this engine for Hercules but in my next catalog 1967 it's not there. Model DNXV8TS also called TCD1468 and a marine version, 1468 cu.in.-up to 500 HP turbocharged and weighing in @ 4200-5000 lb. Said to have the turbulence chamber like several others in their lineup but Hercules was talking about the change to direct injection. The turbulence chamber engine had the injector and TC in the block not the head, with injector discharging immediately into the TC where the expanding, ignited mixture discharged into the cylinder/compression space. Different but similar to the Waukesha TC which was in the head.
Old 03-14-2018, 11:21:52 PM
Heins Heins is offline
My book says the engine is DNX V8, 244 HP @1600 rpm. It says it has two camshafts and has mushroom tappets. It may not be overhead cam. It weighs 4200 lbs.
Old 03-15-2018, 08:58:29 AM
If it isn't an overhead cam, they went to a lot of trouble to hang an injection pump on the end of each head. ..
The Following 2 Users Say Thank You to ronm For This Post:
Vintage Hercules Diesel Portable Air Compressors 57donald Live Auctions of Engines, Tractors and Old Iron 2 06-04-2016 04:50:17 PM
Hercules ZXB flat head engine 1951 vintage bigreo Generators & Electric Motors General Discussion 11 03-06-2016 08:36:44 PM
Vintage Decora air compressor... Just how Vintage? Metal Twister Farm + Industrial Antiques and Collectibles 3 12-19-2015 01:49:34 AM
Vintage Earth Moving Demonstrations & Vintage Equipment Show RHHS Canada Shows and Swap Meets 0 08-08-2012 12:11:48 PM
Vintage ad for the Hercules fans... F6Forrest Antique Gas Engine Discussion 3 12-22-2010 07:23:44 PM
