Mystery Diesel Engine Help Needed
this thread has 14 replies and has been viewed 1228 times
Old 03-13-2018, 12:43:55 PM
Sonny Reese Sonny Reese is offline
Default Mystery Diesel Engine Help Needed
I need to get a fuel transfer pump for this engine in my chipper and the numbers are leading no where, so I need ideas!!!
all I can get off tag back up in top left rear corner of air duct is:
1054 U
431165
80 hp
May be another number above this tag with a number, but heavy paint covering it , so cant read it yet.
Thought it was Deutz 4 cylinder, but no such number from Deutz! Got any ideas! I really need this chipper going right now so I can do a big job with it!--fuel transfer pump got weak and quit, stopping the engine dead in the water!
Thanks a million for any ideas you might have!! thanks; sonny
Old 03-13-2018, 01:14:14 PM
dependable dependable is offline
Default Re: Mystery diesel engine help needed
What kind of chipper? My Brush bandit has a 4 cyl Perkins in it.
Old 03-13-2018, 02:29:16 PM
Russell Walker Russell Walker is offline
Default Re: Mystery Diesel Engine Help Needed
If it is air cooled and resembles a Deutz it could be a Hatz.
Old 03-13-2018, 04:21:16 PM
Chipper has no tags anywhere that I can find.-- It looks like old vermeer , but they say that they never used air cooled diesel engines, so that's another mystery!--Looks factory, but it could have been re-powered I guess!--still lookin'!
Fuel pump has BCD---made in Italy stamped on it and looks bout like the ole 292 gm engine pump. thanks; sonny
Old 03-13-2018, 06:17:26 PM
How about disconnecting the dead engine lift pump and hooking up an electric pump to push juice from the tank to the injection pump.
Old 03-13-2018, 06:33:20 PM
here are a few pix. of the chipper, (2 are front and back of engine) thanks; sonny
Name:	20180313_155232 chipper1.jpg
ID:	305467   Click image for larger version
ID:	305468   Click image for larger version
Name:	20180313_155251 chipper engine.jpg
ID:	305469   Click image for larger version
Name:	20180313_155314 engine backside.jpg
Old 03-13-2018, 07:20:17 PM
moteurdelco moteurdelco is offline
it is a VM MOTORI serie 105 (1052,1053,1054,1056). I dont remember if this serie was later or earlier than the 2-105,3-105,etc.
in Canada they were distibuted by DETROIT DIESEL ALLISON.
Old 03-13-2018, 09:42:34 PM
enginenut2 enginenut2 is offline
This suggestion is just a W.A.G. but seeing the banjo fittings , like Deutz,on the lift pump makes me remember how some European engines hid a fine filter screen in banjo fittings and in the case of deutz under a small cover plate on top of the pump.If you didn't read the manual you probably wouldn't expect them to be there. They were obviously intended to be inspected and cleaned often--like valve adjustment-often. Many of these engines, as good as they are, were not friendly to the average American way of scheduling maintenance and they acquired a bed reputation by the not so caring user.
The Following User Says Thank You to enginenut2 For This Post:
Old 03-14-2018, 01:56:46 AM
Motormowers's Avatar
Looks like a Deutz air diesel with that shrouding and push rod tubes. Actually it is a V M Motori as the shroud is on the injector pump side on a Deutz I believe??
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Last edited by Motormowers; 03-14-2018 at 02:00:03 AM. Reason: I spaced and thought wrong
Old 03-14-2018, 08:16:22 AM
That is one vintage chipper,, in nice shape. Almost looks like an Asplunde "wisper chipper" not that they were quiet. Have not used a drum style one like that since early 90's.
Old 03-14-2018, 10:01:02 AM
The chute is round and most pix. have square ones.--This unit runs like a banshee!--will work a crew hard feeding it! lol!!
The closest I could find was a pic. of a woodchuck chipper, similar, but not exact so still don't know.
At least now we know it must be VM motor, which is Italy made.--Banjo fittings don't hsve screens in them, checked for that,-- had pump off and diaphram worn out, no suction, so may have to go electric, as parts place can't cross a mech. pump to it. thanks; sonny
The Following User Says Thank You to Sonny Reese For This Post:
Old 03-15-2018, 09:45:22 PM
Had to rig a temporary fuel tank, and install an electric fuel pump to get the engine to go, since I can't get parts for Italy made engine here! thanks; sonny
Old 03-16-2018, 07:21:39 AM
edward moller edward moller is offline
looks like the same fuel pump as used on an IVECO diesel. check with you locale NEW HOLLAND dealer. tn55 uses the iveco engine.
Old 03-16-2018, 10:56:41 AM
kwfiggatt kwfiggatt is offline
I found a website of a fuel pump mfgr in Slovenia that lists pumps for VM Motori engines. Here's the link --> ptz pumps
Although I didn't find a pump specifically for the 1054U engine, they list one for a 2,3,4 cyl engine, their part number 6217. Here's the link --> https://www.ptzfuelpump.com/en/fuel-...-pumps/pn-6217
You might drop them an email and see if they have one for your application. If nothing else, you can compare yours with the pics of the ones they list on their website and probably find a match. I'm sure they could ship worldwide.
Hope this helps.
Kevin
Hope this helps.
Kevin
The Following User Says Thank You to kwfiggatt For This Post:
Old 03-16-2018, 02:00:59 PM
That sure looks close!---gotta contact them!---Thanks for the link!!! sonny
Mystery Engine Help Needed. Empire? Gerlacr Unidentified Engines 9 10-16-2013 08:48:02 AM
Mystery Diesel in Alaska pjd Vintage Diesel and Oil Engines 2 09-12-2012 10:50:47 AM
Mystery Marine Diesel inferno Onan Generators 23 12-21-2008 10:47:39 AM
Mystery Diesel Engine Jim McIntyre Generators & Electric Motors General Discussion 3 02-25-2007 12:14:23 PM
Mystery Diesel Patrick M Livingstone Antique Engine Archives 2 06-02-2002 09:47:02 PM
