Smokstak Down Under
Wisconsin Stationary Engine, How do I work out how many horsepower?
this thread has 12 replies and has been viewed 859 times
Old 03-30-2018, 02:25:30 AM
Britstand Britstand is offline
Default Wisconsin Stationary Engine, How do I work out how many horsepower?
Hi just wondered if anyone could tell me how many horsepower this Wisconsin engine is?
ID:	306933   Click image for larger version
The Following User Says Thank You to Britstand For This Post:
Old 03-30-2018, 02:36:49 AM
Scotty 2 Scotty 2 is offline
Default Re: Winsconsin stationary engine how do I work out how many horsepower
Google is your friend.
http://www.wiengines.com/product/30
For parts
http://www.wiengines.com/support_repair_spec/30
Old 03-30-2018, 01:45:19 PM
s100 s100 is offline
Default Re: Winsconsin Stationary Engine, How do I work out how many horsepower?
It is 9.2 HP
Old 03-30-2018, 10:11:46 PM
K-Tron K-Tron is offline
Id like to agree with you that it is 9.2hp, but it is not. I have very small amounts of literature on the Norton/Villiers, and Ronaldson Bros. & Tippett built Wisconsin engines. There are a few subtle differences in the castings, but the most noticeable difference is the magneto. I believe all of the R&T built engines had Lucas magneto's. Its hard to tell in your picture, but the magneto looks like a Fairbanks Morse. At 2000rpm your engine will produce 6.1hp.
Chris
Old 03-30-2018, 10:41:13 PM
Chris
Hello Chris.
Why would the Wisconsin site say rated power is 9.2 as per the link I posted?
At 2000 rpm the Wisconsin literature says 6.1hp.
At 3200rpm it says power is 9.2hp.
Cheers Scott
Old 03-30-2018, 11:20:54 PM
Scott, The tag on his engine says RPM 2000.
When you dig into the nitty gritty of the AEN versus AENL differences, you will find that the governor flyweights on the AENL are lighter for higher speed operation. If this engine in question was designed to run at 2000rpm, it would most likely have the heavier AEN flyweights in it. The higher speed AENL engines do not govern well at mid range speeds due to the lighter governor flyweights.
Chris
The Following 5 Users Say Thank You to K-Tron For This Post:
Old 03-31-2018, 05:27:42 PM
Thanks Chris.
I do enjoy learning and I appreciate the time you've taken to explain things better.
Cheers mate
Scott
Old 03-31-2018, 05:42:59 PM
I read the tag as AENLD ? Yet it clearly states 2000 rpm.
Old 03-31-2018, 08:34:03 PM
Vanman Vanman is offline
Just yesterday I was looking at a nice, but way overpriced, 1800 rpm generator set, powered by a 1978 Wisconsin AENLD.
Old 03-31-2018, 08:49:27 PM
mschreiber mschreiber is offline
Default Re: Wisconsin Stationary Engine, How do I work out how many horsepower?
Just 2day i looked at a complete jan 1944 aeh with belt pulley on it. no compression and overpriced.
Brownwall Gas Engine Horsepower? tjohnson Antique Engine Photos 4 10-09-2014 11:43:31 AM
What is the Horsepower of this Engine? Denis Rouleau Antique Gas Engine Discussion 6 06-03-2012 09:57:27 PM
United Engine Horsepower? jdwyer23 Antique Gas Engine Discussion 6 12-24-2011 01:14:19 AM
Will this work on my Wisconsin AEH? Chris Schmidt Magnetos, Ignition Coils and Spark Plugs 0 01-16-2011 04:11:38 PM
Horsepower on an onan engine Jasonl007 Onan Generators 1 06-11-2009 04:27:17 PM
