Push rods
this thread has 2 replies and has been viewed 514 times
Old 12-09-2018, 06:13:00 PM
Moline Moline is offline
Default Push rods
has anyone ever heard of solid push rods causing any damage to the cam or anything else? would they be to heavy?
-Randy
Old 12-09-2018, 07:35:49 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: Push rods
With the low speed of those engines the weight of the lifter isn't too big of an issue. It's the type of metal and degree of hardness in the finish that makes the lifter not gall with the cam lobes. Using the wrong metals is the fast way to destroy a camshaft. As far as push rods go, many older engines use solid cross section push rods from new. Light weight tubular ones came about for higher speed engines to lower reciprocating weight to better balance the valve train.
Old 12-09-2018, 08:25:10 PM
OldThresherM OldThresherM is offline
Agreed.The type of metal and hardness are the key.My 1929 John Deere D had a bent pushrod when I bought it.Thankfully there was no apparent camshaft damage.Even though the cam has no support bearings in the center.
Cockshutt 40 push rods. Wayne Riedlinger Antique Farm Tractors 3 10-09-2015 10:05:12 PM
Farmall 350 Diesel Head Gasket and Push Rods Needed Bill Lloyd Antique Farm Tractors 10 03-14-2014 08:14:54 AM
1940 Farmall B push rods question Blackriver Antique Farm Tractors 3 09-15-2013 12:27:59 PM
Wanted: McCormick Deering 10-20 Push Rods junkyard4$ Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-26-2012 09:58:26 AM
Homemade Push Rods Virginia Mike Antique Gas Engine Discussion 5 10-11-2007 08:18:36 AM
