Homebrew Diesel (Built by Elden DuRand 2018)
this thread has 12 replies and has been viewed 1796 times
Old 01-29-2019, 02:37:58 AM
David Jones David Jones is offline
Default Homebrew Diesel (Built by Elden DuRand 2018)
Elden DuRand was a member of the Smokstak community and frequent poster. Like a lot of you, I followed him here and on his website www.eldensengines.com, often commenting and providing suggestions on his various projects. I especially liked his Homebrew HVID engine and frequently encouraged him to build a true injected diesel engine. Elden was very fond of diesels so it did not take much encouragement to get him to build what I have named the Homebrew Diesel.
July 31, 2017, was his first official post suggesting that he would begin working on a diesel design. Elden studied various methods of developing a simple injection pump and injector. In addition, he constructed an injection tester so he could evaluate his injector designs. By late August, 2017, metal shavings had begun to fly at the Hoyt-Clagwell & Company (name of Elden's machine shop) facilities, Port Saint Joe, Florida.
After several attempts at making a successful injector, he decided to start building engine parts and lay the injector aside. He wanted to do more research on an injector design, something he could construct given his limited machining capabilities.
Construction of the engine continued at a rapid pace, and by May of 2018, the basic block and crankshaft assembly were complete. He posted a need for some small valves, so I harvested a pair from a 4-stroke weed eater and mailed them to him. On May 27, 2018, he had first ignition--from a naphtha soaked rag held against the engine intake port.
He then turned his attention to the injection system. Another follower named "Doc" had sent him some Lambordini pump parts. After studying these parts, Elden decided he could incorporate them into his pump housing. By June 12, 2018 the injection pump was complete.
Focus now returned to the pesky injector. After a couple of attempts he was able to construct an injector that worked. He was not happy with the spray pattern, but felt it was adequate.
June 22, 2018, saw the engine on skids with an Elden signature brass radiator mounted and plumbed. Two days later, he was able to get the Homebrew Diesel to run under its own power ("off-the-belt," as Elden would say). The injector continued to be a problem, so a new poppet style was constructed.
June 26, 2018, was the first attempt at engine operation with a working governor. After adjusting the timing the engine was able to sustain itself at a governed speed. The video:
https://www.youtube.com/watch?v=Hihq...ature=youtu.be
June 28, 2018, Elden turned his attention again to improving the injector. Using his Dremel ,he was able to reface the injector poppet and get an improved spray pattern. However after just a couple of hours of run time the engine would loose compression and quit. Removal of the head revealed the valves had carbon buildup and were not sealing. In addition, the piston rings were full of carbon sludge, causing them to stick.
Several more run attempts were made, all resulting with the engine quitting due to carbon build-up under the valves and loss of compression. Elden tried many things, various angles on the valve face, stronger valve springs, heat-treating the head, and even valve rotors. None of the changes corrected the problem. During these modifications, he constructed a fuel tank, lift pump and day tank using a Lukenheimer oiler jar which had been given to him at the Florida Flywheeler show in Zolfo Springs.
Another poster had suggested to Elden that it could be the exhaust valve duration was too short. A new cam was machined and fitted to the diesel. After about an hour of running, it lost compression and quit. Here is the last video of this engine made by Elden.
https://www.youtube.com/watch?v=ZnvG...ature=youtu.be
Elden continued to refine the injector. He increased the popping pressure to 1500 psi which improved the spray pattern, yet the engine would continue to clag up the exhaust valve and quit. August 22, 2018, Elden posted that he had been given "light duty"--doctors orders. He was having health issues and would need open heart surgery.
October 10, 2018, Hurricane Michael was a direct hit on his home and shop in Port Saint Joe, Florida. It totally destroyed everything. This was two weeks before he was scheduled to have the heart surgery.
October 27, 2018, Elden contacted me and advised me he was getting rid of everything and wanted me to have the Homebrew diesel. He did not have a place to store or keep it, and I needed to pick it up within two weeks as it was exposed to the elements in Florida. My wife Angie and I got in our trusty 1996 VW Passat Diesel wagon and headed to Port Saint Joe Florida. We were unprepared for the decimation and destruction we encountered. Homes, businesses, utilities, and trees, had all been reduced to piles of rubbish with automobiles, boats and the like entombed together. Elden and Elaine were living in their motor home parked in their driveway. We spent the day visiting with them and their friends, (from Kentucky) who were there assisting them with removal and cleanup. We loaded up the Homebrew diesel, said goodbye and headed back to Texas.
I continued to correspond with Elden via e-mail and text. He was eagerly awaiting his heart surgery, now scheduled in Birmingham, AL, as his local hospital had been damaged by the hurricane. On January 9, 2019, I was notified by Elden's nephew that he had died January 6, 2019, due to complications from his surgery.
I, like many of you, will miss Elden's frequent posts and updates to his web pages. My goal of this thread is to continue to allow his readers the opportunity to follow the development of the Homebrew diesel. The picture attached is of Elden and Elaine sitting on the back of our car with the Homebrew diesel as we were getting ready to depart for Texas.
David L. Jones
Old 01-29-2019, 02:51:05 AM
Here are some detail pictures of the Homebrew diesel as received from Elden DuRand;
ID:	327434   Click image for larger version
ID:	327436   Click image for larger version
ID:	327437   Click image for larger version
The Following 3 Users Say Thank You to David Jones For This Post:
Old 01-29-2019, 03:06:51 AM
In my discussions with Eldon, he believed the clagging problems were associated with incomplete combustion due to fuel not being atomized by the injector. I agreed with him and my initial focus will be to attempt to improve the injector design using a pintle style injector. I have attached some of my initial designs and will show the construction progress of the new injector.
Name:	First Sketch of Pintle Injector.JPG
ID:	327439   Click image for larger version
Name:	First Cad Drawing of Injector.JPG
ID:	327440   Click image for larger version
Name:	3D view of Injector.JPG
The Following 2 Users Say Thank You to David Jones For This Post:
Old 01-29-2019, 03:12:04 AM
Some progress, one step forward and two back. Given my limited machine shop experience and quality of tools, I have made several attempts and have figured out what does not work.
Name:	Injector Body with Threads and Pilot Hole.jpg
ID:	327442   Click image for larger version
ID:	327443   Click image for larger version
ID:	327444   Click image for larger version
The Following User Says Thank You to David Jones For This Post:
Old 01-29-2019, 03:23:23 AM
Making progress, have slightly modified the design as I go. The size of the parts make machining very difficult given my skills and equipment. The allen screw is a 10-24 and it will have a lock nut when finished. The end of the pintle will need to be trimmed flush. The pintle style injector relies on the fuel pressure to lift the pintle to allow injection to occur. If the clearance is too great between the pintle and the housing, the fuel will bypass the pintle and just exit the return line to the tank. I lapped the pintle to the housing but still have too much clearance. I can only build 400 lbs of pressure before the fuel leaks by and exits via the bypass (return). Next step will be to explore the use of an O-ring on the pintle piston.
ID:	327446   Click image for larger version
ID:	327447   Click image for larger version
The Following 6 Users Say Thank You to David Jones For This Post:
Old 01-29-2019, 09:14:14 AM
TekNik TekNik is online now
Default Re: Homebrew Diesel (Built by Elden DuRand 2018)
David,
Thank you for continuing the work on Elden's diesel.
I followed the project on Elden's website, and will continue to follow it here.
Thanks,
TekNik
Old 02-04-2019, 12:39:00 AM
Brief update. I machined a groove on the pintle piston to accommodate the installation of a size 60 O-ring. The bore of the injector is .203 and a size 60 O-ring is .250 OD. After installation I used my Dremel and the lathe to grind it down to work in the injector bore. This picture was taken after it had been in and out a few times and was showing wear. The O-ring has solved the bypass leak I was having. I am now able to adjust the injector from 0 to 1,500 psi. I seem to get the best pattern around 800 - 900 psi. I am getting more of a stream instead of the fog I was expecting. I re-installed the injector and attempted starting the engine. Could not get any injection exhaust smoke, so I backed off the injection pressure adjustment until I got smoke in the exhaust. I then removed the injector and checked the pressure setting. It was around 200 psi. Above that pressure I am not getting any injection to occur. I now need to look at the pump to figure out why I am not getting high pressure. Regarding the injector pattern, my pintle has a straight section after the seal flange. I may need to re-design it where the seal area is at the very tip of the injector. I believe the straight section is why I am not getting more of a fog.
Name:	Injector with O-ring Installed.jpg
The Following 4 Users Say Thank You to David Jones For This Post:
Old 02-15-2019, 09:54:31 PM
I disassembled the injection pump and re lapped the surfaces between the barrel and injection pump discharge valve. I got the pump working again, however not at the pressure I am targeting. I would like to get the injection pressure between 1,000 and 1,500 psi. I was able to get the engine to run with the injection pressure of 600 psi. However I had to retard the injection timing to get reliable injection to occur. I believe that compression pressure exceeds the injection pressure and therefore I don't get injection. By retarding the timing cylinder pressure decreases and allows injection. Due to the retarded timing, the engine is very smokey (white smoke). Seems to make adequate power. Elden limited the stroke of the pump trying to make it flow less fuel. The limited stroke causes the injector pump to dump fuel before it reaches high pressure. I will do some tweaking and see what I can come up with. I will try and post a video of it running in the next couple of days.
Any thought or ideas appreciated.
David L. Jones
Old 02-17-2019, 02:25:13 AM
I got a chance to work on the Homebrew Diesel today. I am trying to develop a reliable way to determine the actual injection timing and be able to adjust it accurately. I also removed the head to clean and lap the valves. I took some pictures with the head off, my timing indicator, and clag on the exhaust valve.
I also made a video showing the pintle injector spray pattern. My drill battery was about dead and kept shutting off during the video. That is the strange sound you hear which caused the engine to slow down.
https://youtu.be/IR59cyIruys
ID:	328809   Click image for larger version
ID:	328810   Click image for larger version
ID:	328811   Click image for larger version
ID:	328812   Click image for larger version
Old 02-17-2019, 04:49:48 AM
David: I'm the "Doc" follower you mentioned in your first post.
The injection pump and parts I sent Eldon were off a 6LD435 Lombardini. The complete shop manual for which can be downloaded here: https://drive.google.com/file/d/0B1p...w?usp=drivesdk off my gdrive.
The parts were from an engine that suffered a catastrophic failure with around 635 hours on it. I mention this strictly as an indicator of possible wear.
There is a section in the manual that covers specs and testing for the pump and other injection components.
Hope this is of some assistance to you.
Doc
"I could while away the hours communing with the flowers if I only had a brain.."
Elden Durand jfikes01 Oil Field Engines & Related Equipment 3 01-11-2019 01:43:07 PM
