Wisconsin Engines
chrome rings
this thread has 2 replies and has been viewed 3087 times
Old 06-16-2005, 08:57:27 PM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
Images: 26
Default chrome rings
Here's a good question,
I finished restoring a briggs 6hp 143330 engine recently. I installed a set of NOS chrome rings. The briggs book specifically says not to hone which I followed. It worked great and sealed perfectly. Now I have a Wisconsin BKN that I again have a set of NOS chrome rings that I want to use, and in the instructions in the package, it says to specifically hone the cylinder. What gives and why would you have to hone with these?
Thank you
Mike
Old 06-16-2005, 10:39:27 PM
Exclamation Re: chrome rings
Mike,
I take that the B&S was an aluminum block/cylender engine? The Wisconson is a cast iron/cast iron type? Cast iron is extremely hard. The run in time would be excessive, especially if the cylender was highly polished. When you hone the cast iron, you roughen the hard polished surface. The rings will wear faster, and the cylender will take on a good fit to them. The aluminum cylender, and those engines with a steel cylender insert, on the other hand, are relatively soft materials. The exposed surfaces being polished, are slightly harder than the base material. With the rings being hard chrome, basicly, the rings are honing the cylender as the engine runs! The hardened material is 'scraped off' and as it is doing so, it wears in the chrome rings. If you were to hone these 'soft' cylenders, the rings would rapidly remove the soft material on the cylender walls. Without a harder surface to wear them in, the rings will not seat. This leads to blow by, and oil burning , which creates even more heat. Eventually , you have cylender failure. (BOO-HISS) For best results, follow the instructions in this case!
Old 06-17-2005, 09:01:06 PM
Images: 26
Default Re: chrome rings
Thank you for the concise response. Now the mystery is solved, at least for me
Mike
Removing chrome JIM ALL Machine Shop and Tool Talk 8 11-20-2007 11:33:46 AM
Case D Chrome Andy Williams Antique Farm Tractors 0 09-19-2007 10:03:32 AM
chrome removal Dan Dyman Steam Stationary Engines, Traction Engines, Steam Boats 2 04-10-2007 06:54:43 PM
Chrome Oilers Lyle Fall Antique Engine Archives 1 05-02-2004 10:19:39 PM
removing chrome Vernon Antique Engine Archives 15 01-22-2004 06:31:42 PM
