Wisconsin Engines
Wisconsin timing gear
this thread has 2 replies and has been viewed 5536 times
Old 08-24-2005, 01:55:04 AM
Dianna Dianna is offline
Default Wisconsin timing gear
Will a Wisconsin vh4d timing gear interchange with a ve4d timing gear(Wisconsin)?
Old 08-24-2005, 03:46:00 AM
John Newman, Jr.'s Avatar
John Newman, Jr. John Newman, Jr. is online now
Default Re: Wisconsin timing gear
The information I have shows the VH4D introduced in 1956 as a 3-1/4" Bore X 3-1/4" Stroke "even firing" version of the VE4D / VF4D - which has the same Bore & Stroke dimensions.
I don't have a book for the VH4D, but I do have books for the VE4D & VF4D.
It show these both use the following:
Crank gear GA-36-A
Cam gear GB-45-A
Idler gear GC-27-B-1
My book is old (1946) so I don't know if these part numbers are still good.
Since the difference noted in the description is in the firing order, there would have been changes in the crank and the cam. Whether or not the gears remained the same is a good question that I can't answer with complete confidence. I would say that they would probably bolt up, but would they be in correct time? Which motor are you trying to put what gears in?
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 08-24-2005, 11:59:29 AM
Gene O. Carpenter's Avatar
Gene O. Carpenter Gene O. Carpenter is offline
eMail NOT Working
Images: 15
John I have 2 books( both printed after 1970) on the VH4D and they both show the numbers you have listed from your 1949 book are the same !
Gene
Wisconsin Cam Gear Bernie Brown Wisconsin Engines 0 02-02-2008 10:03:05 AM
Sattley cam gear and crank gear timing Judson Antique Gas Engine Discussion 2 11-18-2007 07:21:11 PM
Wisconsin gear box DRoberson51 Wisconsin Engines 3 06-09-2006 06:56:32 AM
Timing Gear Noise hczerwick Antique Engine Archives 4 06-17-2003 01:50:05 PM
timing gear repair lester Antique Engine Archives 9 01-04-2003 12:36:27 AM
