Wisconsin Engines
wisconsin engine
this thread has 1 replies and has been viewed 2571 times
Old 12-10-2005, 02:16:26 PM
texashangman3 texashangman3 is offline
Default wisconsin engine
how to replace points and condenser on a VE4D wisconsin engine. this engine is on a old welder and it is not firing
Old 12-10-2005, 03:26:20 PM
Default Re: wisconsin engine
Is your engine magneto fired or battery & coil? If magneto, the points and condenser are in the magneto. It is necessary to remove the magneto end cap to access the points and condenser. Point gap is set at .015" at full seperation.
If battery and coil operation, the points and condenser are in the distributor and it will be necessary to remove the distributer cap. Point gap is .018 - .022"
Unless points are badly burned or corroded might just need to be cleaned with a point file and regapped. If that doesn't produce spark would check or replace the condsener.
If you don't have an Instruction Book and Parts List for the engine would recommend one. Probably find one on ebay at a reasonable price.
Bill
wisconsin engine BobRR Antique Engine Archives 6 02-09-2003 12:56:07 PM
Wisconsin engine Rodger Antique Engine Archives 2 06-18-2002 06:41:41 PM
Wisconsin Engine F. Osmun Antique Engine Archives 2 12-13-2001 01:05:10 PM
Wisconsin Engine Howard (AZ) Antique Engine Archives 2 05-16-2001 11:58:05 AM
wisconsin gas engine frank Antique Engine Archives 0 01-06-2001 11:01:02 AM
