Wisconsin Engines
Wisconsin no fire
this thread has 13 replies and has been viewed 2706 times
Old 12-25-2005, 04:05:26 PM
Mudcat Mudcat is offline
Default Wisconsin no fire
I've been reading these forums from time to time and have gotten a lot of good info. But one problem I have been having is with my welder. I have an old Hobart Welder with a twin cyl Wisconsin THD I believe. It has electric start and a distributor. The problem is that it goes through condensers like crazy. I have been buying them from the only Wisconsin dealer around but he is older and in ill health. It is hard to catch him in the shop now days. My question is is there an easier sourced or possibly cheaper condenser available and why would I be going through them so quickly. Sometimes they will last through 4 or 5 tanks of gas but others will only last for one or two running sessions. The engine generator does not work so I generally recharge the battery when it starts to cranks slower on start. The welder generator does not work either.
Sorry for being long winded but just wanted to give as much info as I could.
Thank you in advance.
Greg
Old 12-25-2005, 10:38:53 PM
Exclamation Re: Wisconsin no fire
I know it sounds weird, but it sounds like you are overvoltaging the coil. Is there a resister in the ignition circut? Is the ignition switch working properly? What shape are the points in? Burnt up? If the entire system is overvoltaged, perhaps control systems (regulater) is an issue.cranking volts to coil - 12+, run voltage - 6 to 8.
Old 12-25-2005, 11:01:38 PM
Default Re: Wisconsin no fire
I haven't seen any resistor on this setup yet. I will double check tomorrow, as well as the voltage. I was playing with it tonight and it has no sperk while cranking but when I let off the starter button it will show a very weak spark until the engine stops spinning. Seems very weird to me. Points look good and are gapped correctly. I will check the voltages when I get the chance and report the results.
Thanks Andrew
Old 12-25-2005, 11:19:11 PM
sparkplug54 sparkplug54 is offline
sounds like it is the coil or its "leaking" ignition. I had an engine do what your describing, it was fine when the engine was cold and when it got warm and you shut it off it wouldn't start,condensor would burn out. I put a different coil on it and never happened after that. Dan Sheldon
Old 12-26-2005, 12:42:11 AM
skartguy skartguy is offline
Hello You need to make sure you have a resistor type coil on that ing. system if you dont or have a resitience wire in line it will burn up the cond. everytime. if not sure you need to go to the local auto parts and pick up a coil just make sure its a resestor type.....now this is all assuming that you have a automotive type ing. on it. last i remember them wisc. cond wasnt cheap...hope this helps.....
steve.
Old 12-26-2005, 12:58:07 AM
Skartguy,I know what your referring to and it makes sense. I was wondering if a person can buy a resistor like the porcelain type where they can be wired into the coil wires? Dan Sheldon
Old 12-26-2005, 09:29:12 AM
I agree with the coil being the source of the problem, We were once a wisconsin engine dealer, and I was the man you dealt with. Been to several wisconsin schools, back then. Don't have a manual handy for the engine, but, if you have one, check the parts section and get the models of mags used on those, also. I see plenty of them on E-bay, from time to time, and if the replacement coil dosen't fix the problem, search for a working mag, that will definately eliminate the problem
Old 12-26-2005, 11:28:14 AM
Elden DuRand's Avatar
Images: 11
Go to the parts house and get what's called a "ballast resistor" for something like a '60 Chevy, etc.
It's porcelain with a bracket. It has two leads and it goes in series with the wire from the ignition switch to the coil.
Oh, yes - don't worry about having to get a genuine Wisconsin condenser. Get one for the '60 Chevy or a '46 Ford or a '54 Hudson............They're all so close that any one of them will work if it will physically fit.
Take care - Elden
http://home.cybertron.com/~edurand
Old 12-26-2005, 06:05:19 PM
I picked up a wells condensor today for $3.60 put it on and it started right up. I will get a ballast resistor on the next trip to town. I looked at one from a Dodge today but decided to do some checking first. After looking close to the wiring I can see it needs a little attention. I believe I will go ahead and rewire most of the motor and put in the ballast. Try to get the generator and amp guage to working too.
By the way thanks everyone that replied. I will let you know how it works.
Old 12-27-2005, 03:19:15 AM
Ballast from a '68 dodge should work fine. Some systems used a bypass that allowed full voltage to the coil during cranking, to offset voltage loss during cranking. When the key was released from the start position, to run, the switch would default to the resister circut for the coil. Check the function from the ignition-starter switch as well.
Mega fire or Nova to fire Wico?? stugguls Magnetos, Ignition Coils and Spark Plugs 3 02-25-2008 10:25:59 PM
No fire on a 4.0bf-3cr biggerred Onan Generators 10 01-05-2008 09:34:37 PM
Banked fire ? Pete LaBelle Steam Stationary Engines, Traction Engines, Steam Boats 15 06-27-2007 12:21:39 AM
fire extinguishers Chan Mason Antique Engine Archives 9 05-22-2003 09:35:57 PM
What should I check before I fire it up? Norm Generators & Electric Motors General Discussion 3 03-07-2001 12:49:54 AM
