Oil Field Engines
Reid / Prony Brake pictures
this thread has 1 replies and has been viewed 3365 times
Old 07-03-2006, 03:53:59 PM
ListerDiesel's Avatar
Default Reid / Prony Brake pictures
Bruce Babcock asked us to put up these pictures of a Reid engine on the Prony Brake on the 26th June.
Bruce's description of the events follows:
The pictures were taken on June 25, 2006 at the National Threshers show at Wauseon, Ohio. In the photos, Lowell Baker is the owner of the engine and is assisted by John Androvich, Joel Samuelson is reading the RPM of the brake with a hand-held tachometer, Robby Baughman is recording the data, and I am operating the brake. After taking 16 readings, at increasing torque values, I calculated the horsepower at each reading using a vintage 20-inch Keufel and Esser slide rule. The theme of my exhibit is "Measuring Horsepower as it Was Done a Hundred Years Ago."
The pulley on the Reid was too narrow to transmit the full power of the engine, but we were able to get good readings up to 9.5 horsepower with the brake turning 66 RPM. At that speed the scale on the brake registered 140 lbs. (Approximately 730 foot- pounds. The torque at the engine would have been less than this because of the small size of the pulley.) The engine does not have a governor, so Lowell had to adjust his Briggs & Stratton carburetor manually as we increased the load. (I chided him when we were done that his governor seemed to be acting rather erratically.) We started the test at 60 lbs. on the scale with the brake turning 65 RPM. This equates to 3.9 horsepower. I failed to record the diameter of the pulley on the Reid so I don't know the speed of the engine. The pulley was rather small, so the speed would have been greater than the speed of the brake.
It was impressive to hear the Reid come to life as it handled the light load. The photos don't show the size of the small crowd that gathered to watch our experiment. Lowell Baker was certainly, and justifiably, pleased with the performance of his fine engine. I think I can speak for many people when I say "Thank you." to Lowell for what he contributed to making the show more interesting.
The photos were taken by Tricia Baughman.
Peter
ID:	9978   Click image for larger version
Old 07-04-2006, 09:47:48 AM
Tom Sampson's Avatar
Tom Sampson Tom Sampson is offline
Images: 76
Default Re: Reid / Prony Brake pictures
There is a video of the Reid at the thread REID on a brake VIDEO
Tom
Avery photographs on prony brake Andrew Yeary Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 02-13-2007 08:23:03 PM
Reid on Prony Brake? Joel Sanderson Oil Field Engines & Related Equipment 10 11-29-2006 09:21:40 PM
Prony Brake Gary K Steam Stationary Engines, Traction Engines 16 01-25-2006 03:37:53 AM
Prony Brake ihorse Antique Engine Archives 11 11-09-2004 03:09:28 AM
Prony brake Brian Watson Antique Engine Archives 15 01-26-2003 11:48:54 AM
